Old 05-10-2010, 08:25 PM   #1
waterboy1280
61 apache rear
does anybody know what rear i can put in my truck that matches stock one
waterboy1280 is offline   Reply With Quote
Old 05-10-2010, 09:39 PM   #2
slepysal
slepysal's Avatar
Re: 61 apache rear
The only one that will match is one from another 60-62. No others will fit with out some modifying basicly new axle seats or saddles, and a panhard rod. The 60-62 have a difrent frame then 63-66 . Keep this in mind if you order a panhard ( some call it a trac rod) or an axle kit from CPP , they will not work with a 61.
Why are you swapping yours out?
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 05-15-2010, 11:06 AM   #3
rain_man
rain_man's Avatar
Re: 61 apache rear
i have a 61 and have a newer gm 12 bolt in mine
here is some pics
61 step/long bed SBW(SOLD)
NEED A NEW PROJECT
rain_man is offline   Reply With Quote
Old 07-19-2010, 11:11 AM   #4
jku72
Re: 61 apache rear
I've just bought a '62 C-10 with the 3.90 rear gears, and I already own a 1968 12 bolt with 3.07 gears.
Is it just a panhard rod mod to swap?
jku Cornville, Maine
68 C10 burb
42 Willys MB
46 Dodge WF-32 1.5 ton
53 & 56 Olds'
60 Cadillac
22 Dodge Brothers
jku72 is offline   Reply With Quote
Old 07-19-2010, 03:38 PM   #5
raycow
Re: 61 apache rear
No, the mount spacing for the trailing arms is different on the 12 bolt. If you want a bolt-in swap with friendlier gearing, look for a Dana rear out of a 60-62 GMC 1/2 ton.
Ray
raycow is offline   Reply With Quote
Old 07-21-2010, 09:16 AM   #6
jku72
Re: 61 apache rear
Well, the odds of finding a 60-62 GMC in Maine are a little low, but I'll keep looking. Do ALL GMC 1/2 tons have the Dana rear?
I am able to weld, and cut, how hard is it to just alter the 12 bolt?
68 C10 burb
42 Willys MB
53 & 56 Olds'
60 Cadillac
22 Dodge Brothers
Old 07-21-2010, 10:27 AM   #7
ratskin
Re: 61 apache rear
Just curious-wouldn't a '62 with an automatic have better gearing? I'm too lazy to dig out my book to check. I'm thinking of getting a 60-62 (1/2T)automatic rear to put in my '61 3/4T, and getting the spindles off the same truck to make it a 1/2T truck.
ratskin is offline   Reply With Quote
Old 07-21-2010, 10:56 AM   #8
raycow
Re: 61 apache rear
All of the 60-62 GMC 1/2 tons I have seen so far had the Dana. However, as you said, these trucks are not very common. If you don't mind welding on the housing you can use the 12 bolt. Just cut off the trailing arm mounts and re-locate them.
Ray
Old 07-21-2010, 11:10 AM   #9
raycow
Re: 61 apache rear
Chevy offered a 3.38 ratio as a factory option. I don't think it was a stick vs automatic choice. However, after looking at a LOT of these trucks, I have never been able to find one with a 3.38, and that included some automatics. If you are going parts shopping, the center sections will swap 55-62.
Ray
Old 07-21-2010, 01:47 PM   #10
71stub
71stub's Avatar
Re: 61 apache rear
I bolted a 1971 rear axle in my 60 last summer without any modifcations
1971 Cheyenne Short Fleet - 468BB/TH400, Tilt, Tach, PS, PB
1967 Custom Short Fleet - 327/4spd
71stub is offline   Reply With Quote
Old 07-22-2010, 12:17 AM   #11
Captainfab
60-66 Nut
Re: 61 apache rear
I would just move the trailing arm mounts on the '68 12 bolt, add a panhard bar mount, and put that 12 bolt under your truck.
Old 07-26-2010, 10:25 AM   #12
jku72
Re: 61 apache rear
What is the width difference for the trail arm mounts? I guess I could measure the 62, but I haven't even picked it up yet. That'll be another story....
68 C10 burb
42 Willys MB
53 & 56 Olds'
60 Cadillac
22 Dodge Brothers
Old 07-26-2010, 12:03 PM   #13
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Thumbs up Re: 61 apache rear
I have a Ford 8.8 Rear End that will mount up to a 1962 Chevy Pickup....
3.08
Same 1960 -- 1962.
But I am in NC.
http://67-72chevytrucks.com/vboard/s...d.php?t=326263
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
Old 07-26-2010, 01:15 PM   #14
raycow
Re: 61 apache rear
To the best of my recollection, the mounts were off by about two inches when I measured them. I talked to a guy on another board who said he was able to spring the trailing arms enough to bolt in a later rear. This was just so he could tow a parts truck to his garage. There was no way he was going to drive it like that.
Ray
Old 07-26-2010, 01:53 PM   #15
raycow
Re: 61 apache rear
Apparently, the 3.38 gears are now being reproduced.
http://www.classicparts.com/1955-62-...ctinfo/93-513/
If you add the cost of installation parts (bearings, seals, etc) and have to pay someone to set them up, I don't know if it's such a good deal. I installed an overdrive transmission for less than the gears alone cost. A rear end swap would certainly cost less even if you paid someone to do the welding.
Ray
Old 07-26-2010, 03:34 PM   #16
72bigred
Re: 61 apache rear
Bah just move the plates over a couple of inches and modify your pan hard bar or buy an adjustable one for 50$ and your good to go.. Took me about 20 minutes to move my plates and I am by no means a fabricator or super welder.. If you dont have the ability or a welder just take it to someone.. No one would charge you much to move the plates over a bit.. That way you can watch the pick n pull yards or CL and find a rear end with a posi carrier.. I see them all the time up my way for next to nothing..posi carriers for the truck 12 bolt are pretty common and always nice to have that as an option for the future.
72bigred is offline   Reply With Quote
Old 07-28-2010, 08:58 AM   #17
jbgroby
jbgroby's Avatar
Re: 61 apache rear
I did a gear changeout from Precision Gears. All went well and really made the truck just right. From 3.92 down to 3.23
http://rides.webshots.com/album/570438270cjSEvE
jbgroby is offline   Reply With Quote
Old 07-29-2010, 06:24 AM   #18
raycow
Re: 61 apache rear
You got a GMC with a Dana. Us Chevy guys with the old style rears aren't as well taken care of by the aftermarket.
Ray
Old 07-29-2010, 11:51 PM   #19
Captainfab
60-66 Nut
Re: 61 apache rear
Yukon makes 3.38 gears for the GM55T rear differential. They aren't cheap though....
http://www.ringpinion.com/PartsList....ID=37&CatID=10
Ray
Old 04-11-2014, 12:12 PM   #20
Mike Foye
Re: 61 apache rear
I have a 1960 Chevy Apache c30 I am having a hard time trying to find out what rear I have in this truck. I do know its geared 4.88. I want to be able to run faster than 45.
Mike Foye is offline   Reply With Quote
Old 04-11-2014, 02:17 PM   #21
71stub
71stub's Avatar
Re: 61 apache rear
Check the casting numbers on the center section.
Old 04-11-2014, 03:08 PM   #22
66Submarine
66Submarine's Avatar
Re: 61 apache rear
C30 should have leaf springs and an Eaton HO-72. If you have 4.88 gears you don't have an Eaton, as they are 4.10/4.57/5.14 (5.14 was the stock C30 ratio). Common swaps for the Eaton would be the optional 4.10 third member (what I have in my truck), or a complete swap for a 14 bolt.
If you post a picture it's easy to tell if you have an Eaton; the rear cover is perfectly round and it's a third member type with a welded steel housing instead of cast.
1965 C30 pickup 350/SM420/4.10's (daily driver) thread
1968 Impala 4 door sedan (future driver project) thread
66Submarine is offline   Reply With Quote
Old 04-11-2014, 06:22 PM   #23
Mike Foye
Re: 61 apache rear
I will take a picture in a few minutes the old man may have been wrong on his numbers. When you swapped in the 4.10 third member how did your I am assuming 235 like it? Its a panel sorry for leaving that out.
Old 04-12-2014, 12:57 AM   #24
66Submarine
Re: 61 apache rear
Here's a picture of one of mine showing the Eaton rear:
Mine has had the 4.10 in it since I bought the truck. I bought it with a 283 and recently swapped in a 250 six; SM420 ("granny") four speed behind both. I also have fairly large (32" tall) 235/85R16 rear tires.
It does pretty good overall IMO. FWIW, 45MPH is 2,000RPM, 55MPH is a little over 2,400RPM, and 70MPH is a little less than 3,100RPM (I normally drive 55 or 60-65MPH). Does good driving around by itself; towing (around 12,000LBS gross combined weight the times I've done it--7,000LB or so trailer) it does ok, but doesn't like hills all that much (which is to be expected IMO).
Old 04-12-2014, 06:20 AM   #25
Mike Foye
Re: 61 apache rear
Name:  slow ride front.jpg
Name:  slow ride front left.jpg
