05-10-2010, 11:56 PM | #1 |
3inch drop blocks kit
were can i get a kit i cant seem to find one?
and why do i need 8 valves for my airride? what does it do that just 4 valves alone can do? |
05-11-2010, 02:24 AM | #2 |
Re: 3inch drop blocks kit
all i could find was guys using 2 inch blocks so i made some out of 3 inch square tubing 3/8ths inch wall cut iinto 7 inch sections. boxed it in using 1/4 inch flat iron and used a 3/4 inch bit in the drill press to make the holes. there pretty sturdy.. weigh about 5 pds a piece. got them put in the truck today using the original u bolts. just put em in upside down and left the shock plate dragging for now. on payday ill get the 13 inch 5/8ths thread bolts i have on order down at the local parts store.
05-11-2010, 02:35 AM | #3 |
05-11-2010, 08:11 AM | #4 |
i can get a 2inch block and combine it with a 1 inch block but were do i get the u to fit through?
05-11-2010, 08:43 AM | #5 |
67-72 parts collector,…
Stick with a 2" block.
Anything bigger will cause scrubline issues. 2" blocks are too tall with 15" rims.
05-11-2010, 09:43 AM | #6 |
I'm trying to go with tcb1 setup he has 3 inch block setup in rear.
If I can't find a 3 inch kit I'll get a 2 inch kit |
05-11-2010, 10:18 AM | #7 | |
Try a local big rig/semi truck parts house. That's where I get my u-bolts made-to-length. Usually around $35/pair with hardened nuts and washers.
05-12-2010, 08:16 AM | #8 |
why cant i run drop blocks with a 15inch wheel?
whats the cause? |
05-12-2010, 08:34 AM | #9 |
for the sake of everyone's safety on the road, including your own, please don't use anything bigger than 1 1/2" block with a 15" wheel.
05-12-2010, 09:10 AM | #10 | |
Happy to be here
This becomes a concern in the event of a flat tire, especially a blow out. The lowest point of your vehicle is no longer your rim, it's the U-bolts. This could cause a potentially dangerous scenerio where you truck is harder to control.
05-12-2010, 09:26 AM | #11 |
ken's being polite ... it's next to IMPOSSIBLE to control.
