tire lean need advice!!!
after doing my disc convert on my truck the top of my tires lean out
kind of like this \ / is there a way to adjust this I still need to get an alignment but I would like to correct this the best I can on my own for the time being. Thanks Case |
Fabricate till you "puke"
Does it look like you have a boatload of shims tween the top a arm's crossshafts & the mounting point on the crossmember?
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
Yes there is and also some washers that are about 1/4" thick would the best thing be to take out all the shims and if that is to much add one at a time
Those shims are what is used to adjust camber. That's the tilt you have. Can be / \ or \ /. Pull the washers out as I don't think there should be any there. Just keep in mind even with the tires looking like they are vertical they can still be off enough to cause tire wear. Get it aligned as soon as you can.
'68 Short Step LS1/T56, Hydratech, Fatman Fabrications Stage III, Baer, Hot Rods to Hell, US Body, S&W, etc |
I will next week
The washers are not just normal washers they are rounded on the flats |
Washers , with a cup on 1 side to fit next to the cross shaft? My longhorn has them. I would try pulling the shims, & get it close so you can get to the alignment shop.....I wouldnt try driving too much till shes realigned tho. good luck....crazyL
thanks for the info
Make sure you pull equal amount of shims from the front shaft and rear shaft. This way you lessen the possibility of changing the caster. The shims come in two thicknesses. Leave the washer in.
Here are some links that I found helpfully. You can set the chamber pretty close with a small level. I've been trying to perfect my at home front end alignment skills. Not to hard...just takes time and patients http://www.familycar.com/alignment.htm#Cam http://www.allpar.com/fix/alignment.html http://www.vtr.org/maintain/diy-alignment.html http://www.quartermax.com/IHRA/Iss05.html http://www.at-speed.goof.com/writings/alignment Alignment gages. Would like to get some of these but have not found someone in my area that would like to go in halves with me :0) http://www.quickcar.net/chassis/ch_cascamga.html http://www.racerpartswholesale.com/rebco4.htm http://www.racerpartswholesale.com/smart1.htm http://www.racerpartswholesale.com/index.html Frank
69 SWB C/10 5-6 drop 700R4 69 Firebird Convert 455 4 spd 70 Torino GT Convert Austin-Texas |
n
Thats some nice info there Frank!
