slave cylinder bore size??
what is the bore size of the clutch slave cylinder to suit the 1962 master cylinder
cheers |
Senior Enthusiast
Re: slave cylinder bore size??
Napa shows it could either be 1" or 1 1/16"
http://www.napaonline.com/Search/Det...+50014+2014024 http://www.napaonline.com/Search/Det...+50014+2014024
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
#3 | |
Senior Enthusiast
These are the best I have available. Also note, the slave cylinder almost always matches the bore size of the master cylinder. Generally hydraulic clutch linkage is not meant to multiply leverage, merely convey motion by means of incompressible liquid instead of mechanical linkage. If you have a way to measure the bore of the M/C you have, you want the same size slave.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 Last edited by markeb01; 05-11-2010 at 10:18 PM. |
the mc is the factory 62 one,the problem i have is the slave cylinder (not original)piston is coming right out the cylinder when clutch is fully depressed so im thinking the bore size is to small for the mc.When i get some time will unbolt and check it
