Old 05-11-2010, 08:21 AM   #1
drewfever1020
airbag setup!!!!!
i need some help guys
is it nessesary to have 8 valves for an airbag setup?
were can a get a 3inch dropblock kit?
can some one show me a step by step how to install a cnotch and how to bolt in rear bags?
im just wondering if i need to install rear bag cups?
drewfever1020 is offline   Reply With Quote
Old 05-11-2010, 08:46 AM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: airbag setup!!!!!
Look at tcb-1's build thread
Very good write up.
Super clean and detailed.
Most people should look at it for a guide on how to do things right.
You need two valves for each bag.
1 fill valve.
1 dump valve.
Go to CPP's website for alot of good technical install articles.
Keith
Convert to disc brakes.
Old 05-11-2010, 09:38 AM   #3
drewfever1020
Tcb1 setup us exactly the way I'm going iv been looking at his thread for the past few weeks. Beleave it or not I look at it everyday. I just wish he went into more detail.
I've already orderd my bags and airtank.
Got my cnotch already hopping to get it installed by this weekend
Old 05-11-2010, 10:36 AM   #4
lolife99
lolife99's Avatar
Send Doug a PM.
I'm sure he would be glad to answer any questions you have.
Keith
Old 05-11-2010, 11:09 AM   #5
DZL1
One day.....
DZL1's Avatar
Its not necesary to have two valves per bag. You could get away with just four valves. 2 valves for the front and 2 for the rears. I personally have 8 valves because i like to be able to control/tweak my ride height. I can control every corner as i wish. with only 4 valves you would be sharing the fill/dump for the fronts. Same goes for the rears. No individual corner control.
as far as 3 inch block couldnt help you on that. I have a 2 inch on mine. I beleive a 3 inch is too big. When aired out your diff will hit the bed.
Rear bag cups arent necessary. I dont have them on mine will allow you to go lower. Bolt in c-notch is a very easy install. The hardest part is removing the rivets!
Theres a how to on rear bag install w/o cups but i cant find it. Hope this helps.
DZL1.
DZL1 is offline   Reply With Quote
Old 05-11-2010, 11:10 AM   #6
drewfever1020
I will thanks man
Old 05-11-2010, 12:54 PM   #7
tcb-1
Nothing to see here.....
tcb-1's Avatar
thanks for the kind words, gang!
like most will tell you, 8 valves is the way to go. some have gone with 4 valves. a dump and fill on the rear and a dump and a fill on the front. however, connecting both front bags with one line and both of the rear bags with one line will cause lean and yawl on cornering. you need an independent setup that only a 8 valve setup will give you.
spring for a good quality valve. the money spent now will pay for itself later!
take a look over in the suspension section for other members trucks. these guys know a LOT more than I ever will.
make sure you don't ask Keith (lolife99) any questions....... he has a funny way of making your wallet open and cash fly out of it!!! !!
Doug
THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten".
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson
tcb-1 is offline   Reply With Quote
Old 05-11-2010, 01:24 PM   #8
8mpg
8mpg's Avatar
Notch step by step by LFD
http://67-72chevytrucks.com/vboard/s...ighlight=notch
8mpg is offline   Reply With Quote
