Old 05-11-2010, 09:37 AM   #1
knewman9n
knewman9n's Avatar
Motor mount question
Could somebody please tell me the difference between BB motor mounts and SB mounts.Both the perch and mounts.Thanks.
knewman9n is offline   Reply With Quote
Old 05-11-2010, 09:46 AM   #2
Willys47
Willys47's Avatar
Re: Motor mount question
big block mounts have a dish that starts right off the frame rail down tothe motor mount the small blocks have a strait slope to the mount
I was hooked on these trucks since 1982 when I drove my budys fathers 1968 Custum GMC 396 automatic dana 60 rear with a power lock diff what a ride more fun then we will we can ever tell!!
Willys47 is offline   Reply With Quote
Old 05-11-2010, 11:58 AM   #3
knewman9n
knewman9n's Avatar
Can I use my BB towers with a SB?
Old 05-11-2010, 10:50 PM   #4
Willys47
Willys47's Avatar
I would think that you can cause I have heard of trucks with big blocks using small block mounts , but I havn't tried it to be sure.
Old 05-12-2010, 01:04 AM   #5
67/72junkie
bb will not work on sb mounts unless you have shorty headers or get lucky with a certian brand header.I tried to put bb on sb stands and the exhaust manifolds hit the frame stands.same with 2 sets bb headers I had.I had to get correct bb stands.I had sb on bb stands and bb auto linkage on truck I bought with bb removed and sb installed.trans linkage was at an odd angle and wore a grove in the pivot pin. sb auto frame pivot pin may have corrected this with bb stands but I pulled it all and installed all correct sb stuff so don't know for sure on that. once I installed sb stands fan wanted to just lightly rub bottom of bb shroud and I put in correct sb shroud also.it did have aftermarket flex fan and this might have caused rub.
67/72junkie is offline   Reply With Quote
Old 05-12-2010, 10:39 AM   #6
junkyardjohn
junkyardjohn's Avatar
yes you can. been there & done that. john
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
