Hello,
My name is charles.i am workin on a 67 gmc stepside.now i know why you are all here,this thing is fun!anyways it seems someone has pulled a jethro move on my frame to motor mount brackets.someone threw out the stock brackets and got creative with a welder.I knew the only place to look would be here since this is where the c10 guru's reside.can somebody help me out with a set of stock brackets.i shure could use the help.thank you |
![]() Join Date: Sep 2007
Re: Motor mount help
you running an inline 6 or a small block? manual or auto tranny? I have a set in inline 6 mounts if you need them, pm me if you do
1967custom |
Im tryin to drop in a 350 4 bolt and 350 auto trans.
![]() Join Date: Oct 2001
Welcome to the board ratfink13, go ahead read over the forum rules and drop the owner of the board a small fee and become a member of the neatest classic truck forum around, after you have joined then venture over to the 67/72 parts board and place you a WTB thread and tell the guys what you need. V8 sbc or bbc or 6cly engine towers!
happy motoring!! Big O.
Things happen for a reason! |
the best way to go then is to get sbc motor mount towers and mount them in the foward two mount hole locations on the frame.
1967custom |
Do you have a pair for sale?
no I only have inline 6 which would work if you were running a manual trans with no hei
1967custom |
![]() Join Date: Oct 2002
when I install sb for hotrod or performance I use 6 cyl frame stands.swap them from side to side turned backwards in rear frame holes. sb motor mounts. autotrans cross member bolts into factory 6cyl with pwr glide holes and 6 cyl auto trans linkage "longer linkage rod" you can weld ext on sb rod. also uses 56 1/4" 6cyl drive shaft.motor will set back 7" from factory sb position.can also use hei distributor cap .it will clear firewall by 1/4" as long as your cab mounts are not worn out.truck will launch better and ride and handle much better than factory sb position.
