05-11-2010, 01:51 PM | #1 |
HEI install on a 4 wheel drive?
Im trying to replace the points style dist in my jimmy with a hei style dist but it looks like it wont fit becasue of how close it is to the fire wall? Its a small block 400 if that helps any? What am i goin to have to do to get it to fit?
68 C10 LWB 2/4 drop 406/th400/3.73posi 04 Silverado SS LQ9 6.0/4L65e/4.11posi AWD |
05-11-2010, 01:55 PM | #2 |
Under Construction
Re: HEI install on a 4 wheel drive?
another option is a small cap HEI. Skip white (ebay)carries those.
http://cgi.ebay.com/ebaymotors/SBC-C...Q5fAccessories Item number: 350333398793
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 Last edited by my67chevytruck; 05-11-2010 at 02:00 PM. |
05-11-2010, 03:06 PM | #3 |
not enough hours in the day
I have an HEI in my 70 Blazer with a small block. There is probably less than 1/2" of clearance, but it does fit.
05-11-2010, 03:30 PM | #4 |
i wnt have to lift the motor ir pullit to fit it in there?
05-11-2010, 03:31 PM | #5 |
I agree! It is tight, but it will fit. I have to trim my spsrk plug wires locking ring to get a little more clearance. Accel recommends using the locking ring
other option is to slit your firewall and move back at the area of tight fit, maybe later but not right now for me
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 05-11-2010 at 03:33 PM. |
05-11-2010, 03:42 PM | #6 |
I've had the distributor out without having to do more than removing the cap and tilting the distributor forward while lifting it out. I am not using a retaining ring for the plug wires on mine.
05-11-2010, 06:57 PM | #7 | ||
"I ain't nobody, dork."
A regular HEI will fit...
Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
05-11-2010, 07:41 PM | #8 |
It's a street fire so i'm thinking it will be okay
05-11-2010, 08:12 PM | #9 |
What?
Save the point distributor, and buy a Pertronix conversion kit.
Easy hook up, and it looks original.
Chris 1968 K20 Suburban 1972 K10 LWB PU |
05-11-2010, 08:25 PM | #10 |
Gotta agree with this one (even though I have an HEI in my 67) but I have used several Pertronix kits in my JEEPs with great success
Erik 1967 K10 SWB Big Window - Bone Stock 1955 JEEP CJ5 13K orig miles (Resto waiting patiently in the garage) |
05-11-2010, 10:20 PM | #11 |
20' Daredevil (Ret)
I have a GM HEI in my '72 K20 with 350 engine. Tight, yes, but it fits okay. It's been a long time, but I'm pretty sure the cap needs to be off to R&R the distributor.
05-11-2010, 10:43 PM | #12 |
I have Big Cap GM HEI on all 5 4X4's ( 1969 GMC 1/2 ton, 1972 Chev 3/4 ton, 1971 Chev 3/4 ton, 1972 Blazer, 1971 1/2 ton) and the only issue is the cap has to be off to install and remove distributer.
The hold down clamp closest to the firewall takes a little acrobat move---use a short screwdriver to push down while you use your fingers to pull the L shaped catch to the outside. None of mine rub tight on the firewall. The plug wires will touch the firewall, but is not an issue. Good Luck john
1972 3/4T 4x4 Chevrolet (383) 1971 c-10 SWB (400 sb) 1972 4x4 Blazer 1969 SWB 4x4 GMC Projects: 1972 stepside 4x4 http://67-72chevytrucks.com/vboard/s...d.php?t=280132 http://67-72chevytrucks.com/vboard/s...d.php?t=285952 http://67-72chevytrucks.com/vboard/s...d.php?t=553672 http://67-72chevytrucks.com/vboard/s...d.php?t=522704 Last edited by jrdv; 05-11-2010 at 10:44 PM. |
05-11-2010, 11:37 PM | #13 |
I got it in there but haven't got it timed or anything yet! Couldn't get it to fire? The vac advance should be on the right or left when looking at it?
05-11-2010, 11:44 PM | #14 |
It will fit with room to spare. I run a big cap and it fits fine, just doesn't lok like it will.
Ron
Member #111 68 C-10 Daily Driver 70 4x4 Project 76 Jeep CJ-5 Help Support the Board: http://67-72chevytrucks.com/vboard/payments.php He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors. Thomas Jefferson |
05-11-2010, 11:58 PM | #15 | |||
Gary
05-12-2010, 12:21 AM | #16 |
Hmm mines on the right? So what do I need to do to fix thst? Just lift it up a little and spin it?
05-12-2010, 12:49 AM | #17 |
Future TOTM Winner
Also you need to run a new wire to the HEI, your original coil wire won't provide enough voltage. (maybe you have already done this and I missed it.)
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces) 72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts 2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver Check it out www.lsdyno.com |
05-12-2010, 07:51 AM | #18 |
Where does the wire need to come from?
05-12-2010, 10:22 AM | #19 |
Future TOTM Winner
Lots of info on this website about the HEI topic. Here are a couple important ones I got from running a quick search...
HEI Setup Fuse Box Basically you need to run a new 10ga wire from the "ign unfused" tab on the fuse panel to the new HEI cap. Put an inline fuse somewhere on this wire and you should be good to go (I run a 15amp fuse).
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces) 72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts 2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver Check it out www.lsdyno.com Last edited by Critter; 05-12-2010 at 12:24 PM. |
