05-11-2010, 02:12 PM | #1 |
Vin Number query
My Vin is 4C254H136128 I know its a 3/4 ton C 20 No# 136 from Fremont what I cant find the answer for is Engine, trans and rear end? any ideas It appears to be a Dana 60 because of the 8 bolt hub? I think its a 327
05-11-2010, 02:54 PM | #2 | |
"Where were you in '62?"
Re: Vin Number query
http://67-72chevytrucks.com/vboard/s...d.php?t=327764 Please enter VIN number for decoding @ American Classic Truck Parts: http://www.americanclassic.com/paint_test.asp
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread What Are You Workin' On? - 1Bad62ChevyPickup PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN "North and South Carolina Folks Click Here!" (((( ~ I have Parts For Sale & Miscellaneous Stuff ~ )))) "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. |
05-11-2010, 04:47 PM | #3 | |
05-11-2010, 05:43 PM | #4 | |
Here you go: 4C254H136128 "4" = 1964 "C" = Conventional (2WD) "25" = 3/4-Ton "4" = Pickup "H" = Assembly Plant - Oakland, CA Vechicle Production Number -- 136,128 Tell me the rest of your info off your plate!
05-11-2010, 06:16 PM | #5 |
Thanks just got to find the plate..
05-11-2010, 08:57 PM | #6 |
Production moved from Oakland to Fremont in mid 1963. The vin will say H for 64 models, but they were actually built in Fremont. For the '65 model year the code was changed to Z.
05-12-2010, 10:36 AM | #7 |
Thank you
05-12-2010, 08:15 PM | #8 |
It is also the 36,128 made for that year, not 136,128. All vin #'s start with 100,000.
05-12-2010, 10:15 PM | #9 |
Interesting. I didn't know that. So my 64 was really made in Fremont too. I guess that eventually turned into the Nummi plant that just shut down.
Name: Rich Current Ride: 1964 C-10 Short Fleetside Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe Past GM Trucks: 1959 GMC short stepside 1968 GMC short stepside-4x4 1973 Chevy short stepside 1989 Chevy short fleetside-reg cab 1993 Chevy short fleetside-Xcab 2002 Chevy short fleetside-Xcab Save the dinosaurs, use synthetic oil. |
05-13-2010, 10:54 AM | #10 |
cool, I guess I have to crawl under it for the axle details I think the black plate with the gvw rating and such is gone, anyone know what P/S unit fits neatly into a C 20?
05-13-2010, 09:37 PM | #11 |
Any 73-87 power steering unit would work fine, providing you buy the mounting kit from captain fab... There are others available on almost any aftermarket site (I just like buying from fellow board members)... but I think the boxes from around the early 80's switched to metric hose fittings on the boxes, but another board member could clarify what year to be exact. And then you would have to modify your existing column and rag joint assembly to finish off the swap. There are many links here to check out to get the appropriate part numbers for a smooth conversion.
good luck on your conversion, and take some pictures to show us, I've seen a million pics of the swaps... but still like looking at them...LOL
Shawn 1966 short fleet 230 I-6 three in the tree (daily driver) 1966 short fleet big block th400 (building slowly) 1972 c10 3 door suburban 350 th350 (building faster than slowly) 2004 F250 power stroke (not dependable enough to be a daily driver) 2005 Kenworth T-800 Heavy Haul tractor (that's my true daily driver) Last edited by burbguy; 05-13-2010 at 09:37 PM. |
05-14-2010, 03:06 PM | #12 |
I will check into it thank you
06-11-2010, 11:39 PM | #13 |
got it!! Thanks for info
06-12-2010, 09:53 AM | #14 |
Neither the VIN tag (driver side door jamb), nor the GVW tag (driver side kick panel), will identify the original engine, tranny or rear axle in your truck. The GVW tag may list a few engines & bhp ratings, but there are a few engine choices each year.
The original build sheet, sometimes still in the seat springs, will have the engine, tranny & rear axle specifications. Also, you may find the SPID (Service Parts Identification), on the back of the glove box door, that may have this information if it was specially-equiped over the standard equipment. I believe this started in 1966. Sometimes the engine configuration & displacement can be found on the title. On the 4x4 models and some 2wd models, equipped with "no-spin" rear axles with still have the sticker behind the seat back. Last edited by LILRED66; 06-12-2010 at 10:03 AM. |
06-12-2010, 11:47 AM | #15 |
Resistance is Futile
...just bought a powering steering hose for my 'burb. 1979 1/2ton uses the flare style fittings and 1980 1/2 ton uses the o-ring style fittings (metric).
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
08-10-2010, 01:19 PM | #16 |
im kinda still haveing some trouble with decoding my vin this what i got
1502ZF11071B 15/1500 SERISE 02/127'' WHEEL BASE Z/BUILT IN FREMONT F/164-1966 11071/<----------help with this one B/7,000LB's |
08-10-2010, 06:25 PM | #17 |
1961 crewcab
try this thread... gmc and chevy used different vin codes
http://67-72chevytrucks.com/vboard/s...d.php?t=316902
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
08-10-2010, 06:26 PM | #18 |
1961 crewcab
11071 should be sequential production#
11-30-2010, 09:27 AM | #19 |
To the top for the new kids on the block.
