Old 05-11-2010, 03:54 PM   #1
au03z71
au03z71's Avatar
Brake Proportioning Valve
So, the original proportioning valve on my '72 is shot. The front brakes work fine, but the rear brakes are getting no fluid pressure. Turns out my proportioning valve is shot. I took it apart, cleaned everything up, put it back together, and re-installed it and no dice... Anyway, is there a cheaper alternative to buying a direct replacement? Summit has them but I'm not sure how I would plumb it. Anyone ever replaced one of these?
au03z71 is offline   Reply With Quote
Old 05-11-2010, 04:15 PM   #2
skeeterbug
skeeterbug's Avatar
Re: Brake Proportioning Valve
i just swithced my manual disc/drum over to power disc/disc new booster, pro valve, ss lines, and calipers the whole shooting match. i am still not done w/ all the gremlins yet but with all the cool guys and gals on the board im sure you will get plenty of help. to answer your ? there pretty easy to plum just as long as you MAKE SURE you get the correct lines going from the master to the pro. valve, it took me three sets to get the right ones and one set is ss and i cant use them @#$%^& things. good luck
'71 LWB c10-"WORK" in progress
385 ci 4 bolt (4.040 bore), scat 6.0" forged h beams,scat forged crank 3.750, speed pro 5cc flat top, clevite bearings, .039 head gaskets,comp xr288hr 110* 288/294adv. 236/242@.50 555/576 lift, pbm hyd roller lifters, chad spiers 215cc imp. heads , comp 1.6 roler rockers, comp magnum push rods, edelbrock victor jr. single plane intake p&p (1206 gasket matched), quickfuel 750R DP , th 350 trans, 5.14 gear, 3000 stall
2012 best 1/8- 7.70 @ 87mph 1.70 60' (lil better)
2013 best 7.39
2014 best-7.38
New for 2013-strange rear coilovers, headman 1-3/4 headers, 5.13 r&p, .060 aluminum bed floor, 15x14 holeshots w/ 31x18.5 hoosier dot pro's, 15x4 holeshots w/ 26x5.5 m/t skinnies and 200+#'s in body weight loss & 6 point cage
skeeterbug is offline   Reply With Quote
