05-11-2010, 11:35 PM | #1 |
'63-'66 Chevy truck power steering gear box mounting kit
We are releasing a new item...1963-1966 Chevy/GMC 1/2 ton power steering gear box mounting kit. Laser-cut to exact specifications from .250" stainless steel. Includes Grade 8 nuts, bolts and washers, to mount Saginaw powe steering gear box. With slight modifications, these mounting plates can used on the 4x4 and 3/4 ton frames of the same years.
The kit, as pictured, including Grade 8 mounting hardware and shipping, to the lower 48, is $75.00. Payment, via PayPat at: 4-5-6chevytrucks@sbcglobal.net Thanks for your interest and please let me know if I can help you with this item or other good, used '60-'66 Chevy/GMC truck parts in the future. Enjoy the day and be blessed. |
05-14-2010, 10:03 PM | #2 |
TILT COLUMN GURU
Re: '63-'66 Chevy truck power steering gear box mounting kit
I am looking to put power steering in a 64 with a 250 6. do you have pump brackets i can use on that?
kevs_classics64 64 Impala SS Conv 72 Blazer 2wd 75 Jimmy 2wd 63 Belair wagon 02 Silverado ext cab. DD RIP EL JAY |
05-15-2010, 12:55 AM | #3 |
Thanks for the inquiry. I sold my last set to a local fellow, that bought a '64 Chevy C20 lwb fleetside truck from me and he decided to convert to power steering. I come across them, from time-to-time, but I am fresh out right now. Sorry I couldn't help, but thanks for the opportunity. Enjoy the day.
05-16-2010, 10:29 AM | #4 |
We are also offering a similar kit to do the power steering conversion on a factory 4x4.
05-19-2010, 01:15 PM | #5 |
...just another truck junkie..
I was looking around but couldn't find the info. You state that the plates need to be modified slightly to use them on 3/4 ton frames. The question is, what about them has to be modified?
Mike "Bear" Shea |
05-19-2010, 04:45 PM | #6 |
Thanks for the inquiry. You won't find anything online addressing the modifications to do the 3/4 ton or 4x4 power steering conversions, because all of the plates offered are specific to the 2wd, C10 frame rails. The modifications are necessary to shape the plates to fit the contour of the frame rail, since the C10 frame rail is different from the C20, K10 & K20 frame rail.
