Old 05-11-2010, 11:59 PM   #1
72TXSuperCheyenne
72TXSuperCheyenne's Avatar
One Piece Drive Shaft - 72 long bed
Has any one tried using a 1 piece drive shaft with a long bed with a 700R4 tranny?
I need a new drive shaft either way, running a mild 350 CI (250hp, 320 tourque), 12 bolt 3.73 posie rear end. Shaft would measure 71.5" from knuckle to knuckle.
would love to hear good news and bad news from those who went one piece.
thanks, Jeff
72TXSuperCheyenne is offline   Reply With Quote
Old 05-12-2010, 12:48 AM   #2
67/72junkie
Re: One Piece Drive Shaft - 72 long bed
do not use one piece drive shaft in lwb.When you load your truck or hit a hump in the road at speed and make the rear end travel much it will hit in the frame loop and bend it.been there done that years ago.
67/72junkie is offline   Reply With Quote
Old 05-12-2010, 06:23 AM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
it can be done, but you'll spend a lot of money for an inferier piece. Just get your stock shaft cut down and new U joints and a good carrier bearing and get it ballanced. Tell the drive shaft shop that it is now for an overdrive aplication too.
Old 05-12-2010, 10:53 AM   #4
72TXSuperCheyenne
thanks guys.
Old 05-12-2010, 11:48 AM   #5
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
been runniing a turbo 350 behind a one pice for a couple of years no problem
71 Suburban 350/700R4 Project Trixie
72 CHEVY,Highlander,SWB,396,T400
BB72CHEVKT is offline   Reply With Quote
