Old 05-12-2010, 06:51 AM   #1
D.PASSMORE
One of the First
D.PASSMORE's Avatar
WTB-Shifter Parts / Standard Transmission
APP: SM 465 / 4x4 - I need the little square peice that fits at the end of the Z-Bar. It holds the shaft in place on the frame mount. Or If any one has a complete good working assembly - Z-Bar, both ball studs on each end/square retainer peice and push rod that goes from the clutch pedal to Z-Bar. I'll take a look at ...
Update: I've added some pictures. The square peice fits on the outer stud that is mounted in the groove on the frame bracket.
DAVID PASSMORE
ST AUGUSTINE ,FL
ZIP 32084
'71 SWB K/10 CUSTOM DELUXE (Chili)
'72 BLAZER K/5 Muscle Truck (Mule)
'72 LWB K/20 CHEYENNE (Blackie)
D.PASSMORE is offline   Reply With Quote
Old 05-12-2010, 08:49 AM   #2
duallyjams
duallyjams's Avatar
Re: WTB-Shifter Parts / Standard Transmission
what year,I believe there are two different styles.
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 05-12-2010, 09:20 AM   #3
Duncan and son
Hey David, coach me some. We are parting out a 72 350 3sp column shift that was low milage and everything is nice and tight. Will any of these items work for you or is the 4sp 4x4 completely different?
Always appreciate you Paul
You can shear a sheep every year, but you can only skin it once
The person dealing with facts is never at the mercy of the person dealing with theory
1972 Cheyenne Super 402 400 A/c bucket seat tilt custom camper Longhorn
1975 Silverado 454 Crew cab camper special dually
Duncan and son is offline   Reply With Quote
Old 05-12-2010, 04:43 PM   #4
D.PASSMORE
One of the First
D.PASSMORE's Avatar
Its going on my '72 Blazer. I can't find the little square peice at the end (frame side)... Anyway, I believe the Z-bars are different on 2wd and 4 wd and 4 SP top loader compared to a column 3 SP. I might take pictures and post for clarity. Any other comments would be welcome.
Old 05-12-2010, 05:25 PM   #5
michael bustamante
michael bustamante's Avatar
this is from a 67 2wd with a 3 speed and granny gear, floor shift. probably NOT what you need
1967custom
michael bustamante is offline   Reply With Quote
Old 05-12-2010, 07:28 PM   #6
duallyjams
duallyjams's Avatar
I have a 69 4x4 burb with smblk 465 that has the complete set up,I'll try to get pic when it safe to go out side( poring rain )
James
IG duallyjams
Old 05-12-2010, 10:19 PM   #7
D.PASSMORE
One of the First
D.PASSMORE's Avatar
Yeah, that is on the frame. I need the square peice that fits on the end of the outside z-bar/ball stud, which fits in the groove and holds the complete Z-bar assy in place.
DAVID PASSMORE
ST AUGUSTINE ,FL
ZIP 32084
Old 05-12-2010, 10:19 PM   #8
D.PASSMORE
One of the First
D.PASSMORE's Avatar
Sounds good!
DAVID PASSMORE
ST AUGUSTINE ,FL
ZIP 32084
Old 05-13-2010, 08:48 PM   #9
D.PASSMORE
One of the First
D.PASSMORE's Avatar
Ttt
Old 05-15-2010, 08:18 AM   #10
duallyjams
duallyjams's Avatar
I think the part you are looking for is missing from this set up alsoName:  DSCN0966.jpg
James
IG duallyjams
Old 05-15-2010, 09:16 AM   #11
dazza
dazza's Avatar
I re-installed mine a few months ago and after seeing your post I had to go check and see how I did installed it. Maybe I better look for one too! I remembered that mine didn't have it when I took it apart, so that's how I put it back together. Maybe it's on that "don't forget to check before driving" list I have around here!?
I'm not crazy, I'm chosen, there's a difference.
'72 K10 SWB, 350, sm465/np205
dazza is offline   Reply With Quote
Old 05-15-2010, 10:13 AM   #12
D.PASSMORE
One of the First
D.PASSMORE's Avatar
Good news, I found the peice. It was at the bottom of my shop garbage can. My son picked through the garbage before he changed liners and found it. Know idea how it got in there! Anyway, I'll post a picture of it. Thanks
DAVID PASSMORE
ST AUGUSTINE ,FL
ZIP 32084
Old 05-15-2010, 10:18 AM   #13
D.PASSMORE
One of the First
D.PASSMORE's Avatar
I think the part you are looking for is missing from this set up alsoAttachment 584816
Are you parting this set-up out?
Old 05-15-2010, 11:30 AM   #14
dazza
dazza's Avatar
Excellent! So can you ask him check the other cans! I need one!
Old 05-15-2010, 11:35 PM   #15
duallyjams
duallyjams's Avatar
yes every thing is for sale
James
IG duallyjams
