Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1973-1987 Chevrolet & GMC Pickups Parts Board
Old 05-12-2010, 11:47 AM   #1
68chevyfuelie
68chevyfuelie's Avatar
2.5" drop spindles 3/4 Chevy/GMC
Selling these for a friend of mine, they came into the yard last week. They came off of a 1985 Chevy 3/4 ton. Measured against a stock spindle it looks like they would have a 2.5" drop. No idea on the brand, sorry. Comes with or without rotors to save on shipping weight, rotors/bearings/backing plates still on spindles, I can pull the rotors to check the spindles for wear if need be. Looks like just new spindles cost $200 to $250 and up, I'm asking $100 or best offer for both spindles/rotors/backing plates, plus shipping.
68chevyfuelie is offline   Reply With Quote
Old 05-13-2010, 05:41 PM   #2
yellowGT
yellowGT's Avatar
Re: 2.5" drop spindles 3/4 Chevy/GMC
Ill take them if they fit an 89 1 ton crew cab dually. Someone chime in with some answers please.
'84 swb chevy
'69 swb chevy
'68 swb chevy
'95 Impala ss-sold
'89 chevy crew cab dually 3+3
yellowGT is offline   Reply With Quote
Old 05-13-2010, 06:22 PM   #3
joe231
joe231's Avatar
by this link...it should work, but I don't know
http://www.airbagit.com/product-p/spi-gm7191d.htm
CHEVY ONLY
Old 05-13-2010, 06:27 PM   #4
68chevyfuelie
As far as I know, the balljoints will be the same, the difference will be in the caliper/rotors. Someone may correct me if I am wrong, but I believe the 3/4 ton and some light duty 1 tons have a caliper held on by two bolts, whereas the dually's will have a wedge-style retainer. I believe you could use the smaller calipers and be fine, as long as you're not planning to work the bags off the truck. If you need more pic's of the brake mounting area, let me know. Thanks.
Old 05-14-2010, 03:06 AM   #5
JEM
Ironmonger
I'm interested. You've got a PM.
I'd pass on the rotors and the spindles would be going to US zip 94404.
JEM is offline   Reply With Quote
Old 05-14-2010, 03:31 AM   #6
JEM
Ironmonger
I'm not an expert on this but every listing I've seen shows the dually spindles as being unique. That might well be the brake issue mentioned above.
I'm also not an entirely disinterested party as I could use these things for my 2500 Sub...
Old 05-14-2010, 09:11 AM   #7
68chevyfuelie
yellowgt has first dibs, then JEM is up. I'll peel the rotors off when I'm at the yard today and take a couple pics of the spindles. JEM, it looks like shipping would be around $80-100, how does $175 shipped sound? Let me know, I'll give yellowgt a couple days to reply.
Old 05-14-2010, 02:14 PM   #8
yellowGT
yellowGT's Avatar
what would shipping be to 75040? I will also take a look at the spindles on my dually to make sure the brake set-up will work.
'84 swb chevy
'69 swb chevy
'68 swb chevy
'95 Impala ss-sold
Old 05-14-2010, 06:14 PM   #9
68chevyfuelie
I took 12 pictures today, some of other spindles and some of the bare spindles.....got home now....and none of them work. I hate cameras/computers. Sorry. I'll try again tomorrow.
Anyway, I would give the spindles a 9/10 rating, there is absolutely no wear on either bearing surface on either spindle. There is some light surface rust on the one spindle in between the bearing lands, other than that they are in excellent shape.
What I was told for brakes/spindles-
1970-1995 1/2, 3/4 ton and some light-duty 1 ton vans (old body style), 1970-1991 trucks, blazers and burbs (old body style), 1970-1996 forward control all used the same caliper mounting brackets with two bolts, and all control arms and tie rods interchange between spindles.
1970-1976 one ton SRW and DRW used the same setup as above, 76-91 1 ton SRW and DRW trucks/burbs (old body style) and 76-95 vans and forward control used a wedge style retainer. You can use the lighter 3/4 ton stuff on your dually as long as you change rotors/pads. You SHOULD change master/booster, but whatever.
^^^ There are always exceptions to this stuff though!!!
Looks to be about the same shipping, $80-100. JEM asked for just bare spindles, I'd do the same price to Texas as California, $175 shipped, NO rotors/bearings/backing plates.
Thanks!
Old 05-14-2010, 08:29 PM   #10
JEM
Ironmonger
No problem. If yellowGT passes, I'll take 'em.
Old 05-14-2010, 09:12 PM   #11
yellowGT
yellowGT's Avatar
so what you are saying is that I would have to use everything on my dually to make it work but from the info you posted the spindles will work just fine for 1/2 ton pickups right? if so, I will take the spindles themselves. I have the 1" rotors by the way.
'84 swb chevy
'69 swb chevy
'68 swb chevy
'95 Impala ss-sold
Old 05-14-2010, 09:40 PM   #12
68chevyfuelie
What I was told was the spindles will interchange between control arms and tie rods, what YOU have to be careful of is wheel bearings and brakes. I wish my blinkin' camera was working, because I had a few pics of examples. I could be wrong, but I believe 1/2 tons were a smaller wheel bearing, so you may not be able to run 1/2 ton rotors on a 3/4 ton spindle. For you to run these spindles on a 1 ton dually OR a 1/2 ton you should use 3/4 ton wheel bearings, rotors, pads, calipers, master and booster, to do it correctly. I'm just trying to help, I'll take more pictures tomorrow when I'm at the yard. I did call a buddy of mine who works at a parts store and he said the BJ's for a 85 R2500 and a 89 R3500 were the same part number BJ's, but the calipers were different.
Hopefully someone else will chime in here who has tried doing this swap before. Hope this helps.
Old 05-14-2010, 10:54 PM   #13
JEM
Ironmonger
Is there even a 5-lug rotor that'll fit that spindle?
The light-duty C20/2500 were all 6-lug I think, and the 8600GVW trucks and Subs were all 8-lug, and they were all 1.25in rotors.
Swapping to the 3/4-ton front spindles, hubs, rotors, calipers, etc. on the dually will mean changing to the 3/4-ton wheels too.
Old 05-15-2010, 09:24 AM   #14
yellowGT
yellowGT's Avatar
dont worry about it. I was just trying to see if I could use them on one of my rides.
I pass...off to the next one.
THanks.
'84 swb chevy
'69 swb chevy
'68 swb chevy
'95 Impala ss-sold
Old 05-15-2010, 11:00 AM   #15
JEM
Ironmonger
Both half-ton and one-ton spindles seem to be more common than the 3/4-ton pieces anyway, I think you'll be money ahead in the end finding something that's a more direct fit.
Old 05-16-2010, 09:09 AM   #16
68chevyfuelie
Sold to JEM, payment's been made, thank you everyone.
