Old 05-12-2010, 11:49 AM   #1
72tutone
Recommendation for plugs
Can anyone recommend some plugs for a bone stock 350? I need to buy some plugs and wires and I am looking for any good recommendations.
Also is there an easy way to determine on the distrib if its running points, or if it has been upgraded?
Thanks!
72tutone is offline   Reply With Quote
Old 05-12-2010, 01:33 PM   #2
dauntless_powered
dauntless_powered's Avatar
Re: Recommendation for plugs
I have always run what the service manual calls for in my case (283) its ac delco R45's. As far at the dist, pull the cap and rotor, you should either see a set of points or an elctronic upgrade in there. Should be very easy to check out
Erik
1967 K10 SWB Big Window - Bone Stock
1955 JEEP CJ5 13K orig miles (Resto waiting patiently in the garage)
dauntless_powered is offline   Reply With Quote
Old 05-12-2010, 09:47 PM   #3
gonzo6869
Cops, ha, catch me if you can!
gonzo6869's Avatar
I used AC Delco on my 350, sorry I don't have a part number on me right now. If you have an HEI you will want to gap them at 45 otherwise you'll gap them at 35.
72 C-10 Stepper
350/TH350
3.73 in the back
Edelbrock intake and Carb
Hooker Comp Headers
275/60R15 on Rallies
gonzo6869 is offline   Reply With Quote
