Old 05-12-2010, 01:18 PM   #1
72tutone
Bench Seat Problems
So I cannot slide my bench seat forward. After looking underneath the seat I found the wire? going from one end to the other is broke and does not have the s clip in the middle of the seat to hold it.
Is this the only thing preventing the seat from sliding forward?
Is there a replacement repro for this?
72tutone is offline   Reply With Quote
Old 05-12-2010, 01:46 PM   #2
grs
Re: Bench Seat Problems
Just go to a hardware store, buy some wire, and an s hook. Take the seat out, and lube the brackets so they slide easy. Adjust the brackets to the front, and Install the wire, and the s hook. You will have to adjust the wire to the correct tension for it to work correct. Good luck
grs is offline   Reply With Quote
Old 05-12-2010, 02:19 PM   #3
72tutone
Any particular kind of wire?
Old 05-12-2010, 03:19 PM   #4
Sammy
If you are careful not too kink it you may get by with what they call bailing wire. Available @ Farm similar to what they use for bailing straw and stuff.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 05-12-2010, 03:48 PM   #5
72tutone
Knowing my luck it would kink...
Anything from say Depot or Lowes work?
Also what exactly does this wire attach too?
Anyone have a diagram for bench seat?
Old 05-12-2010, 04:03 PM   #6
Sammy
I don't have a pic of what it attaches to, but should be obvious if you have the seat out. They should have some of the bailing wire stuff in Lowes/ Home Depot, just center both rails into even spots on the track and get the wire stretched snugly. If you are missing springs or something in the release mechnism you might need to get those parts from a junk seat on the parts board that someone has.
Old 05-13-2010, 03:40 PM   #7
grs
If the wire kinks just straighten it with needle nose pliers.
Old 07-24-2010, 09:43 PM   #8
67Slider
67Slider's Avatar
I'm subscribed. I have all the springs and the wire too. I need a diagram of how they all fit together. The PO had this thing tore up!!! Any diagrams or schematics out there?
67 C10 Stepside
66 Mustang Coupe
99 Burb 2500
67Slider is offline   Reply With Quote
Old 07-25-2010, 05:46 PM   #9
67Slider
67Slider's Avatar
bump
67 C10 Stepside
66 Mustang Coupe
99 Burb 2500
Old 07-25-2010, 06:07 PM   #10
leddzepp
Moderator
leddzepp's Avatar
X 2. I used a straightened out coat hanger to replace mine, stronger than bailing wire. Still working 4 years later.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
