Old 05-12-2010, 10:40 PM   #1
j-dogg
Heavy duty radiator
It's time to replace my radiator, which is listed as a heavy duty radiator on the glove box. The original radiator was replaced at some point with a non-stock replacement that just doesn't fit right. Here's what I've got: 1970 C-10, 307, manual transmission, no A/C. I don't know if the original was a 3 or 4 core, so any help is appreciated!
j-dogg is offline   Reply With Quote
Old 05-12-2010, 10:50 PM   #2
rsavage
rsavage's Avatar
Re: Heavy duty radiator
I've had 2 core or 4 core original style radiators in the old trucks I've had, never a 3. But I'm no expert. I bought a 4 core original brass and copper radiator like the stock one when I replaced the heavy duty radiator in my shortbed with AC. I paid a little over $200 shipped. If you already have the thicker radiator, you won't need to buy different hold downs. They do make replacement aluminum radiators that are often 3 core or 2 wide cores. I personally don't like the way they look or fit, but that's just me.
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
Old 05-12-2010, 10:53 PM   #3
Sammy
HD rad were usually 4 core and put in A/C trucks. The non A/C trucks with the 3 Spd tranny had mostly 3 cores. What doesn't fit right? If it's the lower rubber mounts that are too wide to seat the rad in then, I would suspect you need a 4 core.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 05-12-2010, 10:57 PM   #4
Sammy
Another indication maybe what engine was installed also. If it originaly came with a 6, 307, or big block. 2 core, 3 core likewise.
Old 05-13-2010, 09:26 AM   #5
j-dogg
Thanks for the help Sammy and rsavage. Sammy - I haven't done a thorough inspection to see what doesn't fit right yet. The truck had the original radiator when I got it about 15 years ago, but my brother took it to a shop a few years later to have a new engine installed (it was originally a 307 and he replaced it with another 307). When the shop installed the engine, they told him it needed a new radiator too, so they put something in that they made "fit", but wasn't a stock replacement. It doesn't look like the original radiator, and it sits too high. It's leaking now, so I am going to go with a stock replacement.
