Old 02-11-2003, 10:57 PM   #1
rayville body
seat swap
will a 88-98 seat be a simple bolt in if i use my brackets?
rayville body is offline   Reply With Quote
Old 02-12-2003, 12:52 AM   #2
79BIG10
I'm back with 2nd truck!
79BIG10's Avatar
I'm curios about this as well. I have heard it's possible but not the easiest.
1979 Chevrolet Bonanza Big10 "Tootsie Roll"
1985 Chevrolet Silverado (wife's)
Member of the Southern Bowties Club
"Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson
79BIG10 is offline   Reply With Quote
Old 02-13-2003, 08:30 AM   #3
85 GMC
New to this board , looks good.
What kinda seats , bench or buckets? What kinda truck?Year?
85 GMC is offline   Reply With Quote
Old 02-13-2003, 09:28 AM   #4
BigRed
I was told by an upholstry guy that it is a pretty straight forward installation if you use your current [edit] brackets [/edit]. You may need some spacers, but that's probably it. If you do it, let us know how it went.
Scott Shelbourne
BigRed is offline   Reply With Quote
Old 02-13-2003, 09:52 AM   #5
85 GMC
if its a bench type , yes you can reuse your tracks. the seats are alittle wider than stock but they fit nicer in the cab.I have a f-150 bench in mine right now. In my 84 chevy I had a 50-50 split bench out of a 96 that fit real nice also.
You just take the risers off the new seat , install yours onto the floor pan , put the seat in and mark your new hole locations. use a selftapping 10 mm bolt (use a 23/64 drill) , You may have to try spreading the tracks apart to get at the struckture of the seat but it works.
If its a 60-40 you have to use a cage , I made mine out of 1x1 square tubing. and weld pads for your stock locations in the floor.once you get it in place and at the right highth.
Be aware that if you use a power driver seat it is to high , you can't remove the risers and the power from beaneth the seat to lower it enough. Your knees will hit the sterring wheel
Old 02-13-2003, 10:33 AM   #6
79BIG10
79BIG10's Avatar
You got any pics? Sounds like a good setup you got 85 GMC.
Old 02-13-2003, 11:54 AM   #7
85 GMC
Which one did you want to see. There is'nt much left of the 84 , but my 85 has the ford bench in it , Ill see if I can find m pics of the interior.
Old 02-13-2003, 12:05 PM   #8
Low87
been here longer than Liz
Low87's Avatar
Originally posted by BigRed
I was told by an upholstry guy that it is a pretty straight forward installation if you use your current browsers.
It doesn't matter IE vs Netscape?
~Greg~
Mac's Garage
'87 SWB 6/8 drop "Piso"
'08 CCSB Silverado DD
the departed
'89 GMC K5 Jimmy 4x4 "Rusty Nuts"
'77 Chevy K5 Blazer 2wd
'83 Chevy stepside
"You get what you pay for" - Mike 'swervin ervin' Ervin
Low87 is offline   Reply With Quote
Old 02-13-2003, 12:10 PM   #9
85 GMC
I'll take some pics when I take my truck to the bodyshop tonight and i''ll post them in the a.m.
Old 02-13-2003, 12:27 PM   #10
85 GMC
go here , I have 2 pics if you look close you can see the cage underneath.
http://photos.yahoo.com/bc/shortbox1...Photos&.view=t
Old 02-13-2003, 01:50 PM   #11
BigRed
DOH
Today has been busy at work. I'm a programmer and I had browsers on the mind. Good catch.
Scott Shelbourne
