Under hood paint??
Under the hood, sould the wheel wells be body color or black? Mine are rusty and I cant tell what color they ever where...
'71 Chevy 3/4 Ton Longbed '22 Chevy Tahoe RST '67 Firebird- 8 sec street car '24 GMC CC 4x4 Duramax Dually |
Re: Under hood paint??
Stock color was black
72 GMC
gloss, semi-gloss, or flat ?
thanks |
I painted mine semi gloss, but my dad has a brand new set of oem and they are pretty flat.
![]() Join Date: Sep 2009
When you get NOS inner fenders they come with black primer which is pretty flat but they still need to be painted. Semi gloss is the closest as it will flaten over time.
Hope that helps Paul
You can shear a sheep every year, but you can only skin it once The person dealing with facts is never at the mercy of the person dealing with theory 1972 Cheyenne Super 402 400 A/c bucket seat tilt custom camper Longhorn 1975 Silverado 454 Crew cab camper special dually |
I use Krylon Satin Black part no. K51613 now. You can also order industrial semi-flat black part no. 1613, which is closer to oem. Dupli-Color DE1635 is also good, I hear.
Active Member
![]() Join Date: Jul 2007
I used black rustoleum on mine. Turns real hard after a few weeks of heat from the engine and sun.
I use the Dupli-Color DE1635 and it looks real good
http://www.picturetrail.com/jwill41 67 1/2 ton GMC short step side 68 1/2 ton Chevy long fleet side 72 1/2 ton Chevy Suburban 99 1/2 ton Chevy Suburban founder (and only member) of the primer/clearcoat club |
There are some "chassis black" paints out there. It's suppose to be close to original. I would call it satin. If you want a rattle can napa has martin senour chassis black that seems to work really well.
72 GMC
thanks everyone
I painted mine the same color as the truck as well as painting the core support. Gives the engine bay that extra pop.
![]() My WIP ( Work in Progress ) Last edited by DaddyO; 05-14-2010 at 10:12 PM. |
I've got one of each. Like Daddy0, I think body color gives it that extra pop.
How 'Bout them Dawgs! ![]() '10 Traverse LTZ 03 Silverado Z71 ext cab 99 Yamaha Grizzly 600 72 C10 350/350 sportside bed. 68 C30 flatbed. 350 4-speed. "I've got a good memory, it's just short!" |
