Old 05-13-2010, 12:17 AM   #1
wyomech
wyomech's Avatar
56 cluster
so here is my home made cluster using autometer fuel and temp gauges and speedometer
wyomech is offline   Reply With Quote
Old 05-13-2010, 12:30 AM   #2
Kim57
Kim57's Avatar
Re: 56 cluster
Very nice. I like the gauges and tach.
Kim
Kim57 is offline   Reply With Quote
Old 05-13-2010, 09:33 AM   #3
Tri5Nerd
Tripple Five Fanatic
Tri5Nerd's Avatar
Re: 56 cluster
I like it, what about a AMP and Fuel guage? Are you going to use them?
Tri5
1955 Chevy Stepside/LS1 drive train
http://67-72chevytrucks.com/vboard/s...d.php?t=371513
Tri5Nerd is offline   Reply With Quote
Old 05-13-2010, 10:20 AM   #4
wyomech
wyomech's Avatar
Re: 56 cluster
there wasnt room for all 4 gauges so I havent made up my mind wether too mount them under the dash or cut holes in it
Old 05-13-2010, 12:14 PM   #5
OrrieG
OrrieG's Avatar
Re: 56 cluster
Looks great, I am having the same challenge but I also want to mount a trans temp guage to monitor trans temp while crawling thru the boonies. I have seen 58-59 dashs with the ash tray smoothed and guages mounted in the dash below the V. Amp and volt meters are overrated, I have never had an old rig with one that worked. Gas you just need to keep it filled up and track how far you drive. Oil pressure and temps are critical and I'll take a tach over speedo too.
OrrieG is offline   Reply With Quote
Old 05-13-2010, 12:50 PM   #6
wyomech
wyomech's Avatar
Re: 56 cluster
I used a electronic speedo because I am running a 4l80e transmission and there isn't a cable drive gear
Old 05-13-2010, 04:27 PM   #7
jjjmm56
jjjmm56's Avatar
Re: 56 cluster
Nice work. Looks just as good as a store bought.
jjjmm56 is offline   Reply With Quote
Old 05-13-2010, 04:58 PM   #8
Fred T
Cantankerous Geezer
Fred T's Avatar
Re: 56 cluster
Looks good. I've been trying to figure out a way to get your other gauges in the dash. Looks like enough room to put one on each side outside your cluster. But they need some trim to blend them in with this panel. I was thinking of a small version that only holds one gauge.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 05-13-2010, 06:16 PM   #9
wyomech
wyomech's Avatar
Re: 56 cluster
I have a couple ideas but not sure yet ,thinking about an aluminum panel to fit in the ash tray hole ,half the fun of these trucks is figureing out how you want something to look or work.
Old 05-13-2010, 07:19 PM   #10
OrrieG
OrrieG's Avatar
Re: 56 cluster
Here is a photo to think about, apoligies in advance if it is someones truck on this board. I think there are two on the other side of the cluster too.
Old 05-13-2010, 11:14 PM   #11
CAL 58 GMC
CAL 58 GMC's Avatar
Re: 56 cluster
I like it!
CAL 58 GMC is offline   Reply With Quote
Old 05-14-2010, 12:48 AM   #12
hotrodrookie
hotrodrookie's Avatar
Re: 56 cluster
Im loving the look of those gauges. Im gona do something similar and mount any extra ones in the stainless housing I made, I havent got around to finishing it, but you get the idea.
hotrodrookie is offline   Reply With Quote
