05-13-2010, 01:06 AM | #1 |
79 scottsdale 454 as a doner for a 63
A local guy has a running one cheap, is most of this usable ( motor/tranny/subframe,front suspension )
Would it be 8 lug cause it's a one ton ( sorry about that stupid question ) and if so can you put 5 lug rotors on it. Thanks |
05-13-2010, 01:37 AM | #2 |
60-66 Nut
Re: 79 scottsdale 454 as a doner for a 63
Yes a 1 ton will have 8 lug hubs whether it is a single wheel or dual wheel 1 ton. No you can't just put 5 lug rotors on those spindles. The engine and trans will fit without issues, as well as the power steering and the rest of the braking system. You could possibly use those lower control arms (not positive on the 1 tons) along with some other '88 and later parts and have 6 lug disc brakes. If the truck is affordable and runs and drives, I would go for it.
05-13-2010, 02:11 AM | #3 |
Thanks Captain I appreciate the help, I'm still Chevy pickup stupid, ask me something about VW or BMW and I got your back.
05-14-2010, 01:32 AM | #4 |
60-66 Nut
No problem, let me know if you need anything else.
05-14-2010, 03:17 AM | #5 |
05-15-2010, 12:31 AM | #6 |
60-66 Nut
Ummmm if I had that connection, I wouldn't be sharing
