05-13-2010, 09:07 AM | #1 |
Rear frame section????
How much difference is the rear frame secton from a 67-68 to a 64-66?
Getting me a free leaking aluminum rear mount gas tank this weekend from a 68. Luckly the business I am in, I have access to an aluminum tank fabricator that can fix the leak or leaks for free as well I hope. Can't beat that. Thanks guys, Cody |
05-13-2010, 01:49 PM | #2 | |
Re: Rear frame section????
05-13-2010, 02:48 PM | #3 |
So there is a good chance the tank can work?
05-13-2010, 04:04 PM | #4 |
Yes. A 69-72 blazer tank would fit & is a common swap so other rear tanks that would fit a 67-72 should work as well.
05-13-2010, 04:20 PM | #5 |
Thanks that makes me happy.
My boss has a 89-91 parts Suburan. I am going to rob the steering column, foot emergency brake setup, hood release, 700r4. Is it worth using the front suspension from too? Last edited by cl08; 05-13-2010 at 04:20 PM. |
05-13-2010, 06:26 PM | #6 |
yeap i had a 91 sub front suspension on my 65
65 c10 tore apart 70 c10 305/350th |
05-13-2010, 09:53 PM | #7 |
Definitely worth it if the price is right.
05-14-2010, 09:06 AM | #8 |
Suburban price is FREE!!!! Just have to pull the parts. He bought it for the front sheet metal for his 74.
These parts will bolt up right or little to no fabrication correct? |
05-15-2010, 12:35 AM | #9 |
60-66 Nut
Yes the '89-'91 2wd Suburban front suspension, brakes and steering will bolt up with little modification and a couple aftermarket brackets. They are the same as the '73-'87 pickups.
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 05-15-2010 at 12:36 AM. |
