02-11-2003, 11:03 PM | #1 |
Oil Pressure Reading
Any ideas on why the oil pressure pegs the needle on start up?
Using the stock gauges at the moment. Just changed oil and filter, in case there was a possible problem. Was awful black. After initial warm up it still shows about 3/4 on the gauge. Don't know if the engine has had work on it or not. Appears to be the stock 350 that was stock.......
1970 Chev CST 2003 Harley Fatboy 1975 Chevrolet Step Van 1956 Chev Bel Air 1977 Blazer 2WD For Sale $3000.00 1978 Blazer 2WD For Sale $7000.00 1978 Silverado 2005 Monte Carlo |
02-11-2003, 11:10 PM | #2 |
What weight oil did you use
'72 1/2 ton short box 468 BB forged crank/rods/pistons full roller. Msd 6 AL ignition turbo 400 tci. 2800 verter ladderbar/coil rear with currie built ford 9'' rear, 4.11 gears custom built rear frame tubbed, 33/19.50/15 rear m/t. m/t skinnies in front still under construction |
02-11-2003, 11:20 PM | #3 |
Don't know what was in it before the change.........
I use Valvoline 10-40 in everything I drive...... Before and after the oil change the readings are the same.........
02-11-2003, 11:23 PM | #4 |
u should be happy that u still got oil pressure that that good i dont exactly remember what pressure is when the stock guage is pegged but its good.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
02-11-2003, 11:38 PM | #5 |
Fabricate till you "puke"
the stock guage is pinned on my 79 at about 55-60 psi. It stays pinned till it warms up, then comes back to about 3/4 guage @ idle(in park). The 355 has about 15,000 mi on it, & runs a hi press pump. It doesnt sound like you have any trouble....crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
02-11-2003, 11:42 PM | #6 |
02-11-2003, 11:54 PM | #7 |
Mine has 10/40 in it also.....crazyL
02-11-2003, 11:55 PM | #8 |
Hmm. sounds like either you have a high volume pump or you are running too thick of oil. I have the same problem but I am running a high volume pump and 10w30, the average temp. right now is around 50 degrees where i live. i really dont think this is a problem.
02-12-2003, 12:02 AM | #9 |
No sir, its a high pressure pump(Z 28 replacement), temps are also a little cooler here in Ill. I have a high vol high pressure pump on the longhorn(melling 10555) that will pin a 80 psi guage when its cold......holds 40psi hot @ idle in park, & runs 70 psi @ 3000 rpms hot......crazyL
02-12-2003, 12:14 PM | #10 |
Old Skool Club
10PSI/1000RPM's
As long as you have 10 psi per 1000rpm's, you're doing good. Anything else is a "gimmee". My guess is that unless your oil pressure is so high that you are losing oil filters (which might happen with cheap ones), then you have no problem. If it makes you feel any better, my oil pressure is at the upper limit of the guage, when it is cold. As it warms up, it drops. When the engine is hot, at idle, the oil pressure is about 10psi. RPM's are at about 650, so I am okay.
If your oil pressure goes UP, when you let off of the gas, you are seeing an indicator of wear in the main bearings. Otherwise, drive it like it belongs to someone else.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
02-12-2003, 01:13 PM | #11 |
Well, thats a bit of a relief. I had the same question as Blue Beard. Mine goes to just past the 3/4 line at startup and gradually comes back down to a lit above half after warm up but I felt like I must have problems. High oil pressure is OK from what I've read here. My motor has high mileage but runs quite well. Oil isn't excessively dirty at changes. Using 10w-30. Does thicker or thinner oil help keep pressures up?
72 Chevy SWB Custom Deluxe K10, 350/SM465, PS, PB, Fact. Air 2000 Harley...Wide Glide |
02-12-2003, 02:30 PM | #12 |
Gman, your pressure sound fine for a stocker with some miles on it. I run 20/50 in my 383 in the hot part of the season, & 10/40 in the cooler months . The pressure seems to run about 5 psi higher with 20/50 in the hot weather, as compaired to the 10/40. CrazyL
02-12-2003, 03:56 PM | #13 |
Young Gun wth Fast Inline
A stock calibrated gauge is suppose to reach 60 psi for everything except the big block. Big block equipped trucks came with an 80 psi gauge. As far as having that much oil pressure, the more the better to a point. It takes power to push all that oil thru and as people have said. 15 psi per 1k rpm is fine with conventional oil and 10 psi with syn. At least thats what i think
1967 Chevrolet LWB with built 292! 415 ft. lbs of torque, 4 speed :O with 27% overdrive too, 3.73 Posi. Frame and body done... getting painted!!! |
02-12-2003, 05:14 PM | #14 |
Just a some thoughts for everyone:
When your BODY has high blood pressure, it is a sign that your blood is too thick or there are potential clogs. The variable displacement, gear type pumps in our engines work under the same principle. 1. Thicker oil gives higher pressure. 2. As the oil warms, it becomes less viscous, therefore thinner. 3. Your oil pressure should vary with RPM like stated above since the pump speed and flow rate is roughly proportional to crankshaft speed. 4. Nominal oil pressure for BB's is 40psi. It drops slightly at idle and should never really be above 60psi at any RPM. 5. An engine with considerable sludge buildup will indicate higher pressure than a clean one with the same pump. The higher pressure is an indication that your pump is working properly but fighting harder to move the oil throughout the ports due to higher viscosity and/or flow barriers. BOTTOM LINE: As long as you have pressure, you are good to go. (that is why there is no redline for oil pressure...)
'72 GMC C20, "2500 Super Custom", Custom Camper, New 454 '93 K2500 Suburban, Old 454 (157K) |
