05-13-2010, 10:48 AM | #1 |
C10 CLUB Y QUE!
1970 steering column
I bought a 1970 steering column off of a truck
do I need to buy a u-joint or anyother product for this instalation |
05-13-2010, 01:26 PM | #2 |
Re: 1970 steering column
no.
Just messin around. I think you can grab the lower section of a mid 70 chevy truck column and bolt it up. Last edited by Joemomma1; 05-13-2010 at 01:28 PM. |
05-13-2010, 01:49 PM | #3 |
C10 CLUB Y QUE!
That would be the lower part were the bar hooks up to the gear box under the fender
Would it be easer to buy a u-joint and if so wich one |
05-13-2010, 03:32 PM | #4 |
Do you just have the column or do you also have the lower section with the rag joint that bolts to the gear box?
05-13-2010, 03:38 PM | #5 |
I you have the upper and lower shaft all you have to do (maybe) is to drill out the bin and collapse the shaft a little and it should bolt right up to you steeing box. (that is all i had to do at least)
05-13-2010, 03:48 PM | #6 |
C10 CLUB Y QUE!
All i have is just the top portion of the culomn
05-13-2010, 09:15 PM | #7 |
and a few others
Sick5, this isn't an "instant message" forum. It may take a couple hours for answers. Bumping and asking the same question over again won't get you an answer any faster.
Be patient, or try dialing 911
Bill US Army Vet -193rd Infantry BlueRidgeMuscleCars.com “The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi |
05-13-2010, 09:24 PM | #8 |
Sick5 you really need the intermediate section with the rag joint to take the vibration out...!
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
05-13-2010, 10:43 PM | #9 | |
C10 CLUB Y QUE!
my double post was an accident that i cannot clear on my cell phone and my bump was clearly a call for help... AND it looks like the last post was at 12pm almost 8 hours ago .. but im sorry for trying to push for just a lil info that i could of got if i just SEARCH for |
05-14-2010, 10:53 AM | #10 |
I can tell you what I did. I used the column from a '64 Impala on my '66. I used a Borgeson ujoint coupler that if I remember right got from Jegg's or Summit. Drilled out the plastic rivets and collapsed and repinned a lower section of a later model truck column and installed it with a new rag joint to my ps gearbox. Hope this helps.
05-14-2010, 11:01 PM | #11 |
C10 CLUB Y QUE!
is that u-joint universal?
05-14-2010, 11:33 PM | #12 |
C10 CLUB Y QUE!
65$ at the junkyard for the lower part of the steering column
05-15-2010, 02:09 AM | #13 |
05-15-2010, 04:44 AM | #14 |
C10 CLUB Y QUE!
well maybe pnp has a 70's
05-15-2010, 09:13 AM | #15 |
http://www.borgeson.com/
They make several types and configurations. I used the one that is splined on the one end and d-shaft on the other. |
05-16-2010, 10:26 AM | #16 |
C10 CLUB Y QUE!
so i have to count the splines for the column and then spline on the bottom connection?
is the bottom connection has splines? |
05-16-2010, 10:50 AM | #17 |
No you won`t have to count splines but it will be sized, 1 inch, or 5/8, I believe, if you get one from a truck it should match up.
05-16-2010, 11:21 AM | #18 |
This is a 73 Van column with a lower from a mid 70's Chevy Truck. I cut the original end off of the truck lower because it didn't match up with the van column and I used a 36 spline/DD u joint that was bought at a local speed shop.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
05-16-2010, 11:53 AM | #19 | |
C10 CLUB Y QUE!
i wanted to use less amount of money as possible. update: i meet up with 62bowtie he said shorten your lower rod with the rag joint and buy a u-joint with 36 and 36 spline looks like next weekend project 3/4 36 spline for the column and whats size for the bottom shaft 13/16 Last edited by Sick5; 05-20-2010 at 11:41 PM. |
06-10-2010, 02:05 PM | #20 |
C10 CLUB Y QUE!
i bought a borgeson 3\4 36 and dd
with a shaft dd using d shaft to replace my ragjoint shaft I hope a have the right size for the column side 70 culomn. Counted the spline 36 not sure it would be 3/4 Last edited by Sick5; 06-10-2010 at 02:34 PM. |
06-10-2010, 09:32 PM | #21 |
Want final install pics when u get it done
06-11-2010, 01:46 AM | #22 |
C10 CLUB Y QUE!
will do!
ima post some pic of a primer job i just did to day in a min |
06-12-2010, 03:38 PM | #23 |
C10 CLUB Y QUE!
update:
ujoint wont be in till monday |
06-14-2010, 09:35 PM | #24 |
C10 CLUB Y QUE!
well here is the ujoint. looking to get started this weekend
ill have more pic when i get started Last edited by Sick5; 06-14-2010 at 11:13 PM. |
06-14-2010, 09:38 PM | #25 |
They look to be stainless from the pics....?
