05-13-2010, 01:31 PM | #1 |
SBC #'s
Can anyone tell me what the #'s that are stamped on the front of the block indicate? I'm pretty sure that it is for the year/make/model/ect. but how do you know what they mean? I have looked everywhere for this informaton and have struck out, so I call out to all my fellow Chevy lovers for some info.
Thanks in advance. |
05-13-2010, 02:01 PM | #2 |
Re: SBC #'s
66 GMC Suburban Custom 66 Chevy K10 Suburban |
05-13-2010, 04:48 PM | #3 |
Re: SBC #'s
Yea I saw that site before and it helped me identify the block, heads, and crank, but unfortunately I have next to zero reading comprehension, so it is still a little foggy to me. I was hoping to find a site that I could just plug in the #'s and wham, bam, thank you mam, the magical answer would pop out. But hey thanks for helping out.
05-13-2010, 10:01 PM | #4 |
Re: SBC #'s
If anyone see's this the code I have on my block is TO725HC, I cant seem to find this code anywhere. Thanks
05-13-2010, 10:05 PM | #5 |
Easy Does It
Re: SBC #'s
try www.mortec.com
05-14-2010, 01:18 AM | #6 |
60-66 Nut
Re: SBC #'s
Here, scroll down this page to where you see the two HC's. It shows it to be either a 275 hp 327 or a 250 hp 350. I don't know just how accurate these listings are. It's been a while, but I'm pretty sure a couple 1965 300 hp 327's I had were the HC code. What heads are on the engine? casting numbers of both the block and heads might help narrow it down.
http://www.nastyz28.com/gm-chevy-cod...s-suffix-5.php This site shows the same thing though... http://www.73-87.com/chevy_ids/scode5.htm
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 05-14-2010 at 01:19 AM. |
05-14-2010, 07:39 AM | #7 |
Re: SBC #'s
Thanks guys, I always thought it was the first two or three letters on the stamping code that you used to look these up not the last. I know it is a 66 327 from the block, heads, and crank, just mostly wondering what the stamping indicated, like for each letter and each number.
stamp TO725HC block 3803352 Heads 3782461 crank 4577 Thanks guys. |
05-14-2010, 03:07 PM | #8 |
Re: SBC #'s
There should be another set of numbers/letters along with the ones you gave. Get those and let us know what they are. They should go similar to 17D198041. Those will tell you the exact month, year, plant and # off assymby plant. And yes, according to the number you posted it is a '65 327, originaly 275 HP or '69 350 with originaly 250 HP.
05-14-2010, 03:58 PM | #9 |
Re: SBC #'s
If there's another set of #'s I dont know where they are.
05-14-2010, 04:36 PM | #10 |
Re: SBC #'s
They will be right near the other numbers/letters (TO...HC) that you posted.
On a Small Block Chevy: Machined pad in front of the passenger side cylinder head. Often hidden by the alterator. Look on this pad and you will find them. Not sure how clean your motor is so you might have to take a wire brush and a stick of chalk to see them. |
05-14-2010, 09:15 PM | #11 |
Re: SBC #'s
If he can see the rear casting numbers at the drivers side behind the left head there`s only three differant castings for the early 327, which here are the last four digits for each, 1362, 2870, 0721, those were offered in `65/66.
T- tonawanda, 07- july, 25-25 day
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip Last edited by Rich 5150 69; 05-14-2010 at 09:18 PM. |
05-14-2010, 09:52 PM | #12 |
"Where were you in '62?"
Re: SBC #'s
All the links below fellas are good sources.
That's where I got my info. Also check out the CSB cylinder Head Casting # thread I started. Got the same info I found from the links below as well. The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums Engine & Drivetrain: The History Of The Chevy Small-Block Motor http://67-72chevytrucks.com/vboard/s...d.php?t=354680 Ford 9" Rear Axle Information http://67-72chevytrucks.com/vboard/s...d.php?t=358081 Ford 9-inch Rear End Length Data http://67-72chevytrucks.com/vboard/s...d.php?t=354261 Big Block Chevy Engine Block Identification http://67-72chevytrucks.com/vboard/s...d.php?t=357304 Camshaft Tips & Definitions http://67-72chevytrucks.com/vboard/s...d.php?t=347969 ((((Transmission Specs )))) http://67-72chevytrucks.com/vboard/s...d.php?t=390542 Small Block Chevy Cylinder Head Identification Small Block Chevy Engine Block Identification http://67-72chevytrucks.com/vboard/s...d.php?t=353538 The (BEST) and (WORST) Small Block Chevys Engines Of All Time http://67-72chevytrucks.com/vboard/s...d.php?t=386581 Big Block Chevy Cylinder Head Identification http://67-72chevytrucks.com/vboard/s...d.php?t=357306
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread What Are You Workin' On? - 1Bad62ChevyPickup PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN "North and South Carolina Folks Click Here!" (((( ~ I have Parts For Sale & Miscellaneous Stuff ~ )))) "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. Last edited by 1Bad62Pro/Street; 05-15-2010 at 05:46 AM. |
05-15-2010, 08:58 AM | #13 |
Re: SBC #'s
That's the info I was looking for, thanks. NtheFamily I'm use to seeing two set of #'s also, but this block only has one set. The block is out of the vehicle and is clean, so I know there is only one set of #'s. Big thanks to Rich 5150 69 for answering my question.
