05-13-2010, 05:30 PM | #1 |
Bench seat
Hi guys,
Maybe a stupid question but will a bench seat from a '84 truck fit in a '79 truck. If so, will it be a simple bolt out the old one, bolt in the new one swap? Or do I have to drill new holes and stuff like that. The reason I want to swap is that I can get a very nice bench seat from an '84 and mine is very bad. Thanks in advance! |
05-13-2010, 06:18 PM | #2 |
Slots go on anything!
Re: Bench seat
It should bolt right in.
1974 Jimmy- 5.3/4L80e/NP241 |
05-13-2010, 07:29 PM | #3 |
Re: Bench seat
it will bolt right up
05-13-2010, 08:48 PM | #4 |
Re: Bench seat
If you are swapping a stock bench seat, here is a tip I learned when working on my 76. If the wire under the seat which controls the seat adjuster is bent out of shape, sagging down, or hard to operate - get a metal turnbuckle with rods for an old screen door at the hardware store. It is just the right length to replace the wire and you will never have a sloppy adjuster again, plus you can adjust the turnbuckle to get just the right amount of tension you want.
05-13-2010, 09:27 PM | #5 | |
Old Heap Driver
Re: Bench seat
_____________________________ Bryan '99 Silverado 1500, 4.3, 5-speed, reg cab, short bed '50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser. '40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver. |
05-13-2010, 09:57 PM | #6 |
house of chevy's
Re: Bench seat
thats is a cool tip
05-14-2010, 01:59 PM | #7 |
Re: Bench seat
Thanks guys, got the seat home now. Will get it in the truck within a few days
