Old 05-13-2010, 06:10 PM   #1
rennalds
leaf spring lowering
Lots of talk here about lowering using coil springs, but I was wondering what are the best options as far as price/ride to lower a 71 cheyenne with leaf springs in the rear
rennalds is offline   Reply With Quote
Old 05-13-2010, 06:19 PM   #2
bad6772
Official Site Guitar Shredder
bad6772's Avatar
Re: leaf spring lowering
A Flip kit is a option......This kit allows or adapts the axle to set on top of the springs....If my memory serves me they are good for 5 to 7 inches...And another option is rear hangers....I am not 100%.But I think they are good for 2 or 3 inches.And there maybe a possibility that you have to notch your bed when both are used......More will chime in and give you a better answer.......
bad6772 is offline   Reply With Quote
Old 05-13-2010, 06:27 PM   #3
tommyd241
tommyd241's Avatar
You have flip kits(5"), lowered leaf springs(2-5"), and shackles(1-2"). You might also have hangers available for your 71 but I haven't seen any for my 68' with the 2.25" leaf springs. I plan on going with a flip kit and maybe a 1" shackle when it comes time to lower my rear end.
'68 SWB Fleetside
'98 K1500 Silverado
tommyd241 is offline   Reply With Quote
Old 05-13-2010, 06:30 PM   #4
rennalds
Are blocks available for our trucks as well??
Old 05-13-2010, 06:34 PM   #5
tommyd241
tommyd241's Avatar
I could be wrong, but I believe blocks are only for the rear coil spring guys or if you want to raise a truck with leaf springs.
'68 SWB Fleetside
'98 K1500 Silverado
Old 05-13-2010, 06:39 PM   #6
tasian
tasian's Avatar
if you flip the axle blocks would then lower the truck
Betsy's build
70 c20 4 speed 406sb
tasian is offline   Reply With Quote
Old 05-13-2010, 06:50 PM   #7
69gmc292
I did a flip kit on my 69 and it lowered it about 8 inches in the rear.
69gmc292 is offline   Reply With Quote
Old 05-13-2010, 06:58 PM   #8
rennalds
damn inches we were aiming for some where in between 4-6 on my sons truck. Are there different ranges to choose from or do you just order one and hope for the best lol??? This one from summit say 4-5" anyone had any experience with it? Thanks for all the input?
http://www.summitracing.com/parts/MMC-63167/
Old 05-13-2010, 07:22 PM   #9
69moneypit
Divorced .....WITH KIDS
69moneypit's Avatar
I had a spring shop to dearch my leafs in a press. Itdropped it around four inches. The ride wasnt bad and it only cost like 200 or 250 if i remember correctly. That was the cost with them removing and installing.
1969 GMC SWB
1975 Chevy Malibu 80k
1963 Ford Galaxie 63k (inherited)
2005 Nissan Armada (wife's idea)
69moneypit is offline   Reply With Quote
Old 05-13-2010, 07:39 PM   #10
exmonkeypunk
Barrito Loco Diablo
exmonkeypunk's Avatar
What about removing rear leafs?
exmonkeypunk is offline   Reply With Quote
Old 05-13-2010, 11:25 PM   #11
chevy71c10
chevy71c10's Avatar
I bought a new set of 4" drop leafs. The springs are 40 years old and I didn't want one side sagging after getting it all together. Cost was about $400.00. Came with new bushings also. I'm under the impression that if you drop 5" or more the frame should be C-notched and will require a modified carrier bearing brace.
Justin
Justin
71' C10 SWB
00' Dakota R/T
05' Z-71 Silverado
16' Z-71 Silverado
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=376904
chevy71c10 is offline   Reply With Quote
Old 06-03-2010, 08:40 PM   #12
exmonkeypunk
Barrito Loco Diablo
for my budget, 400 bucks is a bit much to put into buying new rear leafs. Could i just use new shackles and remove a leaf to get roughly a 4" drop?
Old 06-03-2010, 11:32 PM   #13
made2drag
made2drag's Avatar
exmonkeypunk. you can get 2 out of shackles but removing one leaf will only give you about 1/2 inch. i got 3" when took all out except the main and 2 middle ones. make sure you keep the short flat one also. the ride was decent.
made2drag is offline   Reply With Quote
Old 06-04-2010, 02:26 PM   #14
2ndstoryslam
2ndstoryslam's Avatar
Remove the bed, drill out the rivet's holding the spring perch's. Both end's. Mark/straight edge up how much drop you desire. Re-drill new mount hole's or tack weld in place. Put box back on, have the wheel/tire combo you will be running on truck as well. Like? Good! Remove box, finish the job bolting/weling leave's in place. Wire wheel and sand all metal. top w/ several coat's of semi-gloss black (my Fav!) and reassemble.
2ndstoryslam is offline   Reply With Quote
Old 06-04-2010, 06:00 PM   #15
raycow
If you can weld, or know someone who can, a flip will probably give you the most bang for the buck. You don't really have to buy anything. All you do is cut off the stock spring pads and re-weld them on the bottom of the axle housing. Even if you have to pay a shop for the welding, it might still be the best deal.
Ray
raycow is offline   Reply With Quote
Old 06-04-2010, 06:23 PM   #16
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
Here is how I got 4" out of my rear springs, and it cost me $10. I then cut the fronts to get 3" for free. keep in mind mine is a 3/4 ton though.
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
Old 06-04-2010, 06:32 PM   #17
scooterskoolkustoms
scooterskoolkustoms's Avatar
If you have leaf springs a flip is the way to go.I went to speedway motors and bought new perches @ 12.99 pair 545-85090,and new u bolts @3.99 each 910-43801.I drilled a hole 1" forward on the perches and reused the old plate with a new hole 1" forward.dropped the burb 7" in the rear.under $30.00 plus $10. shipping.
big old burb in primer.lot of work to do.
scooterskoolkustoms is offline   Reply With Quote
Old 06-05-2010, 01:37 AM   #18
C/10 King
C/10 King's Avatar
Thumbs up Re: leaf spring lowering
See below.
We just tried this method on my 67 GMC 1/2 ton short bed (The Toad) ,and it worked out pretty good, one coil was cut and four leafs were removed. The stance looks good,and ride is still decent believe it or not, I will post some pic's hopefully by Sunday evening
C/10 Rene
1966 Short Fleet "The Hag"
1967 CST Short Fleet "Dark Poly"
1971 Short Fleet
1970 Jimmy Custom 2 WD "Golden Ticket"
1972 Blazer 2 WD "Retro Blaze"
C/10 King is offline   Reply With Quote
Old 06-05-2010, 01:52 AM   #19
chevyblazer
chevyblazer's Avatar
yeah flip kit
cucharitas customs
chevyblazer is offline   Reply With Quote
Old 06-05-2010, 02:14 AM   #20
KevsClassics
TILT COLUMN GURU
KevsClassics's Avatar
Originally Posted by C/10 King View Post
See below.
Man! I like doing that.
Instagram
kevs_classics64
64 Impala SS Conv
72 Blazer 2wd
75 Jimmy 2wd
63 Belair wagon
02 Silverado ext cab. DD
RIP EL JAY
KevsClassics is offline   Reply With Quote
Old 06-05-2010, 11:36 AM   #21
sanford66
sanford66's Avatar
Interesting thread! My 68 longbed is sitting on a 72 1/2 ton frame. I'm also wanting to lower mine. The rear sits way to high for me. I didn't think you could get 5-7 inches out of flipping the axle? I know there is a lot of lowering kits out there for 73-87 trucks, will any of these work on a 72?? Or are the 73-87 springs different in length and width? I want to lower mine as cheaply as possible. Joseph
1970 Chevelle Nomad station wagon
1966 C-10 lwb,250-six,granny 4speed
1966 C-10 lwb,factory A/C,Custom Cab
1954 Delray 2-door sedan [rat rod project]
sanford66 is offline   Reply With Quote
Old 06-05-2010, 01:59 PM   #22
dieselarmy13
Phone's ringin Dude.
dieselarmy13's Avatar
Mine is riding on 3 leafs, a DJM flip, and Early Classic shackles (1.5in I think). Still rides like a truck. Word from the wise, if your crappy glasspacks hang below your frame like mine (used to), they won't last long.
I pitty the fool with only two headlights!!
2003 SILVERADO SS--THE NEW GIRL
1972 GMC--THE OLD GIRL
dieselarmy13 is offline   Reply With Quote
Old 06-05-2010, 02:02 PM   #23
dieselarmy13
The leaf springs in 67-72's are 2.25in wide compared to 2.5 on 73 and up, so you have to get a specific flip. I got mine from Stylintrucks. It's been a while, but I think they are like 50 bucks.
Old 06-05-2010, 11:50 PM   #24
Jacfourteen
The amount of drop you get is the thickness of the axle tube plus the thickness of the spring pack. So if the axle tube is 3" and the spring pack is 3" then the drop you get is 6". So depending on the number of leaves you have it may be a little more or a little less.
Old 06-06-2010, 01:54 AM   #25
C/10 King
C/10 King's Avatar
Okay, Here are the pic's.......One old,and four new Tada.......
C/10 Rene
1971 Short Fleet
