How Many PSI does the factory oil guage indicate?
I'd like to know if anyone know how many PSI the factory oil pressure guages are calibrated for? In other words, if it's at the far right hand mark, does that mean 60 pds oil pressure or 80 or what?
Thanks!! |
Location: Help! I'm in an office park with its own network of freeways!
Re: How Many PSI does the factory oil guage indicate?
Most stock gauges are 60 PSI. If you have the gauge out, along the lower right edge it will say "60 PSI" or "80 PSI".
'67 C20--427 tall deck/SM420, 4.10 HO52 (Michigan has not been kind to the Old Man) '95 Caprice--355 LT1/T56/3.42 8.5" 10-bolt (daily driver, almost 300k on the chassis) '07 Outback--wife's car. 125k & counting. No head gasket or transmission issues yet. *fingers crossed* |
Big Red - Now its a SWB!
Mine is 80 lbs, I found out when I had the cluster out. It is labeled right on the back like C20934 said. It probably depends on what motor you have and what pressure it was set up to run, my truck came with a 305 V6.
68 3/4 ton ![]() ![]() 41 3/4 ton ![]() 01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's 02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's |
Moderator
![]() Join Date: May 2007
C/10- C/30 trucks came with 60 lb oil pressure gauges. The C/40-up trucks came with 80 lb gauges. If I am wrong, LHM will correct me on this one.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
I wonder why my truck has the 80 psi gauge in it? I know that it is the stock gauge because my grandad owned the truck since 1971, and he never swapped it.
![]() Join Date: Mar 2000
The only 80 psi gauges I've ever round came out of the C40 and larger trucks.
Saskatoon, Saskatchewan Canada |
Roadtrip!
![]() Join Date: Feb 2003
I have to agree with that. I have seen 60# gauges in bigger trucks, but never an 80#in a 10-30 series.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
I believe 80lb were for big blocks. I don't know if they only used them in big trucks or not. I have pulled several dashes out of big trucks and they were 60lbs.
Turp Mcspray New life for an old 2wd, farm blazer http://67-72chevytrucks.com/vboard/s...d.php?t=505987 My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299 |
its all about the +6 inches
I have no first hand info on this, but I have been told the majority of big trucks, big block trucks, and v6 trucks got 80 pound, the much more common inline and small block truck got 60 psi.
