Old 05-14-2010, 09:55 AM   #1
Oklahoma
Polly bushing's squeek
Last year I put in a set of polly bushings in my A-arms and just the other day they started squeeking, every stinking bump, squeek, squeek, squeek, well you get the picture. Is there a good fix for this other than just spraying something all over them that will collect dust and grime?
Oklahoma is offline   Reply With Quote
Old 05-14-2010, 10:14 AM   #2
bigblock96
bigblock96's Avatar
Re: Polly bushing's squeek
grease,got zerks?
bigblock96 is offline   Reply With Quote
Old 05-14-2010, 12:45 PM   #3
Oklahoma
no grease zerks.
Old 05-14-2010, 12:57 PM   #4
bigblock96
bigblock96's Avatar
I would take them apart and drill and tap for zerks but that's me .
Old 05-14-2010, 12:58 PM   #5
fixit-p
fixit-p's Avatar
Replace them with poly-graphite bushings
1965 GMC shortwide big window
1969 Chevy C20 long (for now)
2005 Silverado 2500HD Crew Cab
Originally posted by:Abraham Lincoln "The trouble with quotes on the Internet is that it is nearly impossible to discern if they are genuine."
fixit-p is offline   Reply With Quote
Old 05-14-2010, 04:01 PM   #6
Oklahoma
I dont think the metal is thick enough to add a zerk, and I'm not to keen on replacing the bushings, I thought the bushings that I got were suppose to be "Squeek Free". I have done alot of work to this truck and really am getting burnt out on it.
Old 05-14-2010, 04:06 PM   #7
forestb
forestb's Avatar
what are zerks
forestb is offline   Reply With Quote
Old 05-14-2010, 04:23 PM   #8
foamypirate
foamypirate's Avatar
For what it's worth, I have poly-graphite bushings on my Honda, and even with a liberal application of chassis grease when installed, they still squeak quite a bit.
foamypirate is offline   Reply With Quote
Old 05-14-2010, 04:52 PM   #9
Ghostwhite
Squarebody guy
Ghostwhite's Avatar
Originally Posted by forestb View Post
what are zerks
Zerk
Ghostwhite is offline   Reply With Quote
Old 05-15-2010, 12:09 PM   #10
mbgmike
When we install them we use Teflon grease but even that will go away eventually but it does last a while
mbgmike is offline   Reply With Quote
Old 05-15-2010, 01:52 PM   #11
nxtruck
nxtruck's Avatar
Turn the stereo volume up a little more!
Seriously, when I replaced mine, they squeeked for a while. But, eventually, they quit squeeking. Unless you take them back apart and coat them with some sort of grease, you'll probably have to live with it for a little while.
Chris
1966 Chevy C10 LWB, 434 sbc, TH350, 12-bolt, factory suspension, pump gas
7.02 @ 95.8, 1.45 60'
1965 Chevy C10 LWB, 355 sbc, TH350, daily driver
nxtruck is offline   Reply With Quote
Old 05-15-2010, 04:55 PM   #12
dracko
dracko's Avatar
i used poly control arm bushings on a pathfinder i had and they squeaked until the day i sold it...and likely still are but at least i don't have to listen to it anymore. I always cranked up the tunes.
dracko is offline   Reply With Quote
Old 05-15-2010, 06:56 PM   #13
Oklahoma
LOL, that is proabably the only reason I heard the squeek, I had the radio turned down the other day and that was when I heard it for the first time.
Old 05-15-2010, 07:24 PM   #14
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Every bushing in my truck is poly, front control arms, sway bar, rear trailing arms, even cab mounts. It is awful. The squeaking and harshness completely remove all enjoyment of driving the truck. Take my advise everyone, go rubber.
Old 05-15-2010, 07:52 PM   #15
muddpile
muddpile's Avatar
I re-did all the bushings in my Corvette with poly. It handles better, rides about the same..... And squeaks..... going on 15,000 miles now.
muddpile is offline   Reply With Quote
Old 05-15-2010, 10:31 PM   #16
likaroc13
Rollin' Old Skool
i wondered about this when looking through your build thread, since i had read some other posts about the poly/rubber debate...my suspension overhaul will be very similar to yours...from reading a few other posts, i had already planned to go rubber when i change everything to 5-lug, but it's great to have your advice!
Old 05-16-2010, 07:17 AM   #17
63 & 64 Bowties
and a few others
One temporary fix would be to go to NAPA (it's not sold at Advance or Auto Zone type places) and buy Ru-Glyde. Spray it on your bushings every couple weeks or so. It won't collect dust, and it's a rubber/poly lube.
Bill US Army Vet -193rd Infantry
BlueRidgeMuscleCars.com
“The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi
63 & 64 Bowties is offline   Reply With Quote
