05-14-2010, 10:17 AM | #1 |
washed my truck....have questions
So yesterday I hand washed my truck for the first time. While doing this I saw a lot of water "peeing" from the bottom of the door (where the drain holes are). I also remember my 72 haveing water slosh around in it cause the drain holes were plugged.
So am I correct that the doors just get water in them....that's the way it is? I have brothers one piece windows and I don't think they seal from the outside as good as factory. Second, I have sound damper (second skin) stuck to the inside of the outer door skin. If/when this gets wet, is it going to trap water and cause rust? |
05-14-2010, 10:57 AM | #2 |
Re: washed my truck....have questions
All of the ones that I have had are/were that way....
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
05-14-2010, 11:10 AM | #3 | |
Active Member
Water will seep into the door. That's why it's important to keep the weep holes open and occasionally take the door panels off and vacuum the leaves and other debris from the bottom of the door. Same thing with the vent holes. Remove the swivel door and stick a vacuum hose down in there. Any where that water/moisture/oxygen can get trapped is a potential rust area. |
05-14-2010, 02:28 PM | #4 |
I am a Referee of life.
Make sure you keep good seals on the outside of the window.It will help keep trash out of the doors and from clogging the weep holes.They will still need occassional maintainence but it's more fun to drive them than keep up little stuff like that.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
