Old 02-12-2003, 01:08 AM   #1
Ron
Ron's Avatar
Electric question
If you were looking for a good "key on" 12 volt source and did not want to cut any wires, where would you connect? Coil maybe? I'm looking for a source to supply 12 volts to an electric choke and do not want to chop up the wireing harness.
'69 SWB
'76 International "Terra"
"Hooked on holiday beer"
Ron is offline   Reply With Quote
Old 02-12-2003, 01:14 AM   #2
'72 Shorty
I finally got an avatar
'72 Shorty's Avatar
You don't want to use the coil unless you've converted to HEI. At least that's my understanding. Before I did the painless harness I had a relay that was powered up from a terminal on the fuse block. I think it was IGN/UNFUSED and took a male blade terminal. That powered all my accessories that the factory never planned on when they esigned the harness.
-72 C-10 short step (straight line only)
12.922/102.28
-69 C-20 on Propane (DD)
-69 C-10
-56 Mack B-753LS (tow rig)
-94 Chev K2500 Short Ex-Cab
-89 Isuzu Trooper...Kinda
-03 Kawasaki KFX-400
-05 Suzuki DRZ-400S
'72 Shorty is offline   Reply With Quote
Old 02-12-2003, 02:42 AM   #3
Andy4639
Old member
Andy4639's Avatar
Cool 12 volts
If you want 12 volts, do as '72 Shorty said. If you hook to the coil as is, when you go to crank the truck the volts will drop off at the coil because of the resister built inside the wire. That's why when you swap to a HEI unit you have to cut this wire. There is a circuit that is 12 volts unfused at the fuse block under the dash.
You cold also hook straight to the battery if you wanted to and put a inline fuse in.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 02-12-2003, 06:22 AM   #4
Lippyp
English Chevy Owner
Lippyp's Avatar
You could do what I'm gonna do and add an auxiliary fuse box powered via a relay switched from the ign unfused terminal. It's exactly the same setup that painless sell as the "Cirkit Boss" add on fuse box but will cost you far less and you can source the components from any good auto elecrical store. See the attached wiring diagram for details. Just make sure that you don't exceed the maximum load you've allowed yourself.
Phil
'67 C10 long fleet.
350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon
2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission
Lippyp is offline   Reply With Quote
