Old 05-14-2010, 10:55 AM   #1
dave01
suspension lift
all i can find is 8" lift for my 69? is there any bigger lift kits out there? i have 43/4 ton axles off of a 74 and the whole drive train. i want to build a truck as big as i can. if anyone has found a bigger lift kit than that i would much appriciate some info thanks.
dave
dave01 is offline   Reply With Quote
Old 05-16-2010, 07:05 PM   #2
AJs72K5
AJs72K5's Avatar
Re: suspension lift
Off the shelf? Probably not. The rear springs aren't the issue as GM used the same length springs on the rears up thru late 80's or so. However, the front length is unique to 67-72. Your best bet is to have some made by Alcan or Deaver. Expect to pay some $$$ though.
Keep in mind that it's not just adding taller springs. Brake lines and driveshafts will need to be lengthened. At those heights you'll also need to either add spring shims or move the perches to correct the huge pinion angle you'll have. You're steering geometry also changes considerably...drop pitman arms and draglinks, raised steering arms will be needed... This is by no means comprehensive, but you get the idea.
- AJ
Gray Matter Build - 1972 K5 with some stuff
AJs72K5 is offline   Reply With Quote
Old 05-16-2010, 11:00 PM   #3
Critter
Future TOTM Winner
Critter's Avatar
Re: suspension lift
I agree with AJ 100% Custom springs would be the way to go. Even if you found something bigger on the shelf the ride quality would most likely be horrendous. One of the custom springs he mentioned would give you the best springs possible especially at that height.
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces)
72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts
2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver
Check it out www.lsdyno.com
Critter is offline   Reply With Quote
Old 05-17-2010, 01:07 AM   #4
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
Re: suspension lift
Yep true that x2 Couldn't have said it better myself. You could also put on a body lift if your not against them to get a bigger lift on there just a thought. Cause if you get springs made up like stated above your gonna pay a ton for em!
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 05-17-2010, 12:40 PM   #5
dave01
Re: suspension lift
hey thanks for the input i called the places you said there about 350 a spring. when add it up plus all the other stuff i will need it's actually not to bad close to what i spent on my new truck and i will get 4 more inch's
thanks dave
