05-14-2010, 02:29 PM | #1 |
steering column?
i have a 66 gmc and first gear and reverse are not working. im thinking the issue is the steering column because a few days ago i had the same issue. i went under the truck and popped it into first manually. i was trying the same today but cant get it to go in gear. a friend suggested that some fork in the steering column may be broken. does anyone have any suggestions?
Also, i looked under the truck and i think im leaking tranny oil, but cant find a dipstick for it. wtf |
05-14-2010, 04:08 PM | #2 |
1965 Chevy C10, 2005 4.8L/4l60
Re: steering column?
manual trans dont have dipsticks, should be a fill plug on one side only. also the linkage at the column used to stick on me when I had my 3speed, I had to use a screwdriver to pry them apart. check that, hope it helps.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
05-16-2010, 08:50 PM | #3 |
thanks for the reply clyde65. i dont think its the linkages at the steering column. they have plenty of space. a friend told me his 51 used to do the same thing and he had some old mechanic repair his. i think i might just have to replace the steering column. i dont think ill know what im looking at if i take it apart.
