05-14-2010, 02:42 PM | #1 |
Air-Engine
Looking to redo my bags, anyone have experience with the air-engine manifold? Was curious about feedback...negative or positive?
05-15-2010, 12:41 AM | #2 |
60-66 Nut
Re: Air-Engine
Pardon my ignorance, but what is an 'air-engine manifold' ?
05-15-2010, 12:57 AM | #3 |
Re: Air-Engine
http://www.airbagit.com/product-p/ai...ngine-8ccc.htm
take a look at the above link, basically it is an 8 valve all in one manifold. Looks pretty cool but unsure about it. |
05-15-2010, 12:49 PM | #4 |
Resistance is Futile
Re: Air-Engine
I haven't used one, but to me the positive is not having to buy about 250 bucks worth of fitting to do the system. They also take up less space. My valves and tank take up the entire area of a spare tire under the truck.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
05-15-2010, 01:20 PM | #5 |
Re: Air-Engine
you can come check out mine if you want, I'm happy with it. If you get the one with fittings for 1/2" line then each bag has it's own slow down valve so the adjustability is nice. like anything else, it has it's negatives too, but ease of installation and $$ saved on fittings make it very worth it. Also, you can get one with all the 1/2" stuff for a lot cheaper than that link you put up
'55 Pontiac - Project '63 GMC - Project '76 Chev stepside rust bucket - Bagged daily driver Project Ru5tyNut5 |
05-15-2010, 04:36 PM | #6 |
SSN 706
Re: Air-Engine
"It takes 1 of these for complete FBSS, one on each corner". What does the one in each corner mean. Did'nt they just say it takes one?:uhmk I'm liking it but do I need 4?
Daverods 64 C10 Daily driver 292 3 speed "Driver" Daverods 66 Build C10 Bags 350/350(On Hold) Daverods 52 Build 3100 S10 chassis,Bags, 350/700r4 "Click it" Last edited by daverod; 05-15-2010 at 04:37 PM. |
05-15-2010, 04:45 PM | #7 |
Re: Air-Engine
you need 1...it's 8 valves in one unit. it takes one line in from the tank and distributes the air to all four corners thru 4 up valves and 4 down vales. It also has 4 fittings for your guages that come from the manifold itself. just mount your 1 unit, run all of your airlines and wire it up and you're done. if you run 1/2" line then you'll have a slowdown valve on each air line and also a 5th slow down valve where the air comes out of the manifold when you're deflating your bags so you have a lot of adjustability as far as speed.
05-15-2010, 04:51 PM | #8 |
Re: Air-Engine
here you go, this is mine...you can see that there is a 1/2" running to each bag and then a 1/4" line that runs to the guages. that one unit is the brain of the whole system, will save a lot of money over using individual valves.
05-15-2010, 06:10 PM | #9 |
SSN 706
Re: Air-Engine
I'm sold. I mean I'm so old. Sweet set up. What size tank/ compressors do you have? Can't wait till my money tree buds. Where's the best deal for the air/engine?
Daverods 64 C10 Daily driver 292 3 speed "Driver" Daverods 66 Build C10 Bags 350/350(On Hold) Daverods 52 Build 3100 S10 chassis,Bags, 350/700r4 "Click it" Last edited by daverod; 05-15-2010 at 06:12 PM. |
05-15-2010, 06:27 PM | #10 |
Yellow truck club
Re: Air-Engine
I think the one big problem is the company itself.
................................................................ Brian ...... My hub garage address http://www.hubgarage.com/mygarage/59apache I gue$$ everything has it'$ price ALL GONE NOW 59 Chev Apache PRAISE THE LOWERED 350 700r lokar shifter power MII front end, shockwaves tilt, 4 wheel discs 4-link and bags 10 bolt limited |
05-15-2010, 08:40 PM | #11 |
Re: Air-Engine
I've made many many purchases from that company and never had a problem so I can't say anything bad about them. I have a 5 gallon tank with two Viair 380c's, and the best deal on the manifold will probably be on ebay, that's where I got mine. There are a bunch of drop shippers on ebay, your buy it from them but the order is shipped from airbagit, you just get it cheaper than the price that's on airbagit.
05-15-2010, 09:38 PM | #12 |
SSN 706
Re: Air-Engine
Looked all over ebay could find it? Any ideas. Not sure what to call it.
05-15-2010, 09:46 PM | #13 | |
Re: Air-Engine
05-15-2010, 10:08 PM | #14 |
SSN 706
Re: Air-Engine
Your the man. Thanks
05-15-2010, 10:25 PM | #15 |
Re: Air-Engine
05-15-2010, 10:29 PM | #16 |
SSN 706
Re: Air-Engine
Now all I need to do get off my a$$ and get some mula.
05-15-2010, 10:34 PM | #17 |
Re: Air-Engine
might have to wait for next years tax return, that's how I got most of my stuff. or you can become a male dancer and try to make a fortune
05-15-2010, 10:43 PM | #18 |
SSN 706
Re: Air-Engine
I was thinking the same thing. I might have to hit the gym first. Maybe some teeth whiteing.
05-15-2010, 10:44 PM | #19 |
SSN 706
Re: Air-Engine
Trying to think of what I can sell on ebay to get my valves. Why does it always turn to sex.
Daverods 64 C10 Daily driver 292 3 speed "Driver" Daverods 66 Build C10 Bags 350/350(On Hold) Daverods 52 Build 3100 S10 chassis,Bags, 350/700r4 "Click it" Last edited by daverod; 05-15-2010 at 10:49 PM. |
05-15-2010, 10:54 PM | #20 |
SSN 706
Re: Air-Engine
Another successful jacking. Had to make up for the last pic.
Daverods 64 C10 Daily driver 292 3 speed "Driver" Daverods 66 Build C10 Bags 350/350(On Hold) Daverods 52 Build 3100 S10 chassis,Bags, 350/700r4 "Click it" Last edited by daverod; 05-15-2010 at 10:56 PM. |
05-15-2010, 10:56 PM | #21 |
Re: Air-Engine
give up the thread beeitch, I SAID GIVE IT UP!!!!!!!
05-15-2010, 10:57 PM | #22 |
SSN 706
Re: Air-Engine
Feedback is all positive I'd say.
Daverods 64 C10 Daily driver 292 3 speed "Driver" Daverods 66 Build C10 Bags 350/350(On Hold) Daverods 52 Build 3100 S10 chassis,Bags, 350/700r4 "Click it" Last edited by daverod; 05-15-2010 at 11:02 PM. |
05-15-2010, 11:05 PM | #23 |
Re: Air-Engine
yup
05-15-2010, 11:06 PM | #24 |
Re: Air-Engine
you showed me your buns so I had to show you mine
05-15-2010, 11:13 PM | #25 |
SAVING ONE TRUCK AT A TIME
Re: Air-Engine
my buddy tim (ory gun) has bags on his suburban now but there manual valves. it takes a week to go up.
