Old 05-14-2010, 09:30 PM   #1
Tri5Nerd
Tripple Five Fanatic
Tri5Nerd's Avatar
I want to make this work
I was at the Pick A Part today looking for a master cylinder reservoir due to the one on my Hyroboost being too big since I'm putting under the cab, I found one that will work and I also found one that was a remote reservoir but the connection to the master cylinder is too small. Take a look at these picts and tell me if I can find some connectors (red circle) to fit (green circle).
1955 Chevy Stepside/LS1 drive train
http://67-72chevytrucks.com/vboard/s...d.php?t=371513
Tri5Nerd is offline   Reply With Quote
Old 05-14-2010, 10:39 PM   #2
blackdiesel
blackdiesel's Avatar
Re: I want to make this work
If you have the mastercyl. that went with the fittings you have. It might fix your booster. just a thought
'57 Chevy Pickup
'56 GMC LCF Cummins
'38 Chrysler Royal
'57 2wd change
http://67-72chevytrucks.com/vboard/s...light=speedway
blackdiesel is offline   Reply With Quote
Old 05-14-2010, 10:39 PM   #3
OrrieG
OrrieG's Avatar
What was in the green circles before? Did they have a hose connection too? Looks like it would be simple enough to use a double barb and splice the hose.
OrrieG is offline   Reply With Quote
Old 05-15-2010, 12:51 AM   #4
Kim57
Kim57's Avatar
Tri5
Whats your hydroboost from? Your master cylinder looks just like mine. The one I got came off an 05 truck and I thought the reservoir would fit under my cab. I moved it back so I don't have to worry about it.
Kim
Kim57 is offline   Reply With Quote
Old 05-15-2010, 01:34 AM   #5
Tri5Nerd
Tri5Nerd's Avatar
The reservior sat there in that green circled area, it snaps in and is locked with 2 pins
Kim57, My Hydroboost is from a 96 Astro Van. I have a reservior that will fit under cab but would like to make the remote work if possible.
Tri5
Old 05-15-2010, 12:20 PM   #6
OrrieG
OrrieG's Avatar
I wonder if a valve cover grommet for a pvc valve or filler would work? I have seen ones that are universal so you can size the center hole. Or maybe a trip to Ace or similar hardware store to look a misc. or plumbing grommets? Is there and internal flow valve or will it be under pressure when you push the cylinder? Or maybe a place that does hydralic and equipment or farm type hoses and fittings??
Old 05-15-2010, 02:32 PM   #7
Tri5Nerd
Tri5Nerd's Avatar
It will be under pressure so I would need to find something that would clamp the connector to the MC. I'll check out some hose shops to see what they have.
Tri5
Old 06-01-2010, 11:26 AM   #8
Kim57
Kim57's Avatar
Tri5
Check this page from wilwood. It has some adapters that may do what you want. You may have to call them to see if they'll fit your master.
http://www.wilwood.com/MasterCylinde...cessories.aspx
Kim
Old 06-01-2010, 01:54 PM   #9
Tri5Nerd
Tri5Nerd's Avatar
Originally Posted by Kim57 View Post
Tri5
Kim
Thanks for the info Kim, I'll give them a call once I measure the width of the outlets.
BTW: Did you ever find the Prop valve fr your hydroboost?
Tri5
Old 06-01-2010, 04:22 PM   #10
Kim57
Kim57's Avatar
Tri5
Mine didn't have one. It's part of the anti-lock brake system. I'm going to run an adjustable wilwood unit.
Kim
