05-14-2010, 10:56 PM | #1 |
sandblasted frame
what is good to treat a frame after sandblasting? rustmort says not to use on sandblasted metal. should i just use an acid based primer? anyhelp would be appreciated.
05-14-2010, 11:04 PM | #2 |
Re: sandblasted frame
the pic on top is where we started the pic on bottom is right befor sandblasting.
05-14-2010, 11:56 PM | #3 |
treat with phosphorus acid,brand name I use is "chem prime''.I get mine by the gallon at local hardware store.I use on all bare metal and then epoxy prime.
05-15-2010, 12:25 AM | #4 |
I had mine sprayed with POR15. That stuff is liquid armor! I've heard it doesn't adhere to bare metal like it does rusted. Whatever, that stuff ain't coming off my frame with nothing less than a grinding pad!
'68 C-10 SWB 383 Stroker (Sold 3/2/2013) '87 R2500 LWB 454 TBI converted to Carb Last edited by AusTx68; 05-15-2010 at 12:29 AM. |
05-15-2010, 12:54 AM | #5 |
thanks , ill give it a shot
05-15-2010, 01:42 AM | #6 |
Id just epoxy prime it...you can go over the primer with whatever you want.
05-24-2010, 07:24 AM | #7 |
Sorry to revive the thread...but how much stuff can you leave on the frame when sandblasting...I have never blasted before so I am really going in blind...do I need to strip the entire frame down? If the cab is still on but the motor, tranny, doghouse, and bed are off, and it is sitting on jackstands (rear end still in, "some" suspension still on) can I safetly do it?
05-24-2010, 08:12 AM | #8 |
bare naked frame is best// anything left on that has bearins etc the blast media will get into
05-24-2010, 11:47 AM | #9 |
Grandpa in the rustmobile...
I covered mine in bedliner..
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
05-24-2010, 02:07 PM | #10 |
man this is what i wanna do next.. i wonder how much it would cost to have powdercoated.
66 Gmc 1 ton. Long Step 351e V6 69 1/2 CHEVROLET (now a shortbed) LONGBED!:devil 61 Shortbed Fleetside 1/2 ton.. in progress Next a 50-53! MY BUILD THREAD http://67-72chevytrucks.com/vboard/s...d.php?t=447926 |
05-24-2010, 03:00 PM | #11 |
POR 15 on mine
05-24-2010, 03:37 PM | #12 |
Check around, I got a quote for sandblasting and powdercoating $400.00
James '68 Stepside (ground up in progress) My 68 build thread http://louisianaclassictruckclub.fre...side-t956.html '81 SWB "Pap paw" (Driver) The 81 build thread http://louisianaclassictruckclub.fre...-swb-t960.html Member of www.louisianaclassictruckclub.com https://www.facebook.com/groups/296290610747732/ |
05-24-2010, 03:53 PM | #13 |
Another phosphoric acid product is Ospho, available at my local Ace Hardware. Put it on right after sandblasting, wait a day and sand or wire brush off the dried excess and Epoxy prime.
72 Fleet (died) 78 Step (sold) 55 Step named Fred (sold) 00 F150 68 Step (named El Scorcho by PO) Build thread for the new El Scorcho http://67-72chevytrucks.com/vboard/s...d.php?t=392932 |
05-24-2010, 05:12 PM | #14 |
If you want durability, I would avoid powdercoating and go with paint or POR15. Powdercoating just sits on top of the metal. My frame is powdercoated and it is not as durable as a properly painted frame IMO.
