Old 05-15-2010, 12:39 AM   #1
81ratrodc10
house of chevy's
81ratrodc10's Avatar
rear disc conversion ?
i have a 5 lug 10 bolt in my c10 what is involved in a conversion and can i do it frome junk yard parts or should i just buy a kit
81ratrodc10 is offline   Reply With Quote
Old 05-15-2010, 01:58 AM   #2
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Re: rear disc conversion ?
Swap in a Caddy or Lincoln rear end. Same 5X5 bolt pattern from the 70's and some 80's model cars. All you do is move the perches. The axels also align the rear wheels to the same travel path as the front. Disc brakes.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 05-15-2010, 11:08 AM   #3
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
theres tons of threads already created on people who have made their own like me, and captian fab. captian fabs uses 12" awd astro van front rotors and d52 (stock style) front calipers. I made my own with some 2004 style dodge rear brakes... havent finished the rear e-brake, but I'm running 13.8" rear discs at the moment and stops great with no work to the p-vave (for now).
heres some linx
captian fabs for sale page:
http://www.67-72chevytrucks.com/vboa...d.php?t=398352
My whole braking system - thinking out loud thread:
http://67-72chevytrucks.com/vboard/s...=392348&page=1
13.8 Rear Disc Conversion for the truck 10-bolt in the works
http://67-72chevytrucks.com/vboard/s...d.php?t=392474
the next brake conversion i will tackle is using c5 rear discs if rotor can fit over the axle flange. I know the fronts will not fit over the axle without machining down the axle... I will go to autozone today and take some measurements. This is the kit I will be replicating but for use with the c-10 rear axle flange. Ive got all the measurements i need except for the offset of the caliper bracket and backing plate. For that I probally will buy a spare rear end at the bone yard.
heres a few pictures of the kit thats offered for the f-body rears...
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
