Old 05-15-2010, 04:23 AM   #1
jdaley
55 step side tub guard removal
I seem to have what Jim Carter truck parts identifies as Carter Heads on the bolts holding the guards [ fenders ] on my 1955 stepside tub. Where can I get a tool to assist with bolt removal please?
John Daley
Melbourne, Australia
1946 Chev Ute
1977 Chev Tray
Road racing sidecars
jdaley is offline   Reply With Quote
Old 05-15-2010, 08:01 AM   #2
blackdiesel
blackdiesel's Avatar
Re: 55 step side tub guard removal
clutch head screws, are what holds them on. All the old truck parts places sell them (lmc, ect.). If you know an old timer with some old tools he will probley have them also.
'57 Chevy Pickup
'56 GMC LCF Cummins
'38 Chrysler Royal
'57 2wd change
http://67-72chevytrucks.com/vboard/s...light=speedway
blackdiesel is offline   Reply With Quote
Old 05-15-2010, 08:55 AM   #3
Kim57
Kim57's Avatar
I got lucky and was able to remove mine with a large flat head screwdriver. If yours aren't rusted to bad it may work.
Kim
Kim57 is offline   Reply With Quote
Old 05-15-2010, 03:37 PM   #4
55454
55454
55454's Avatar
Napa Auto Parts
72 Cheyenne
1956 3100
1955 210
19 year old Chihuahua (Factory Teeth)
55454 is offline   Reply With Quote
Old 05-16-2010, 08:03 AM   #5
fat57
fat57's Avatar
John have you tried ( Snap on guy ) if you do,nt know an owner supply ..Just ask at your body shop want day he come in and see if he can get one in
See-ya Mark Jones
fat57 is offline   Reply With Quote
Old 05-16-2010, 12:48 PM   #6
OrrieG
OrrieG's Avatar
I got my three size set years ago from Jim Carter, I have also seen them at Harbor Freight.
OrrieG is offline   Reply With Quote
Old 05-16-2010, 01:02 PM   #7
yukon ratrod
yukon ratrod's Avatar
what I did was weld nuts onto the bolt heads and had a friend hold a wrench on the other side while I unbolted the fender from inside the box. the heat from welding on the nuts really helps in removing the bolts!
yukon ratrod is offline   Reply With Quote
