Old 05-15-2010, 11:26 AM   #1
Dapper Dan
Dapper Dan's Avatar
leaf spring eye
Picked up some 56" leaf springs at the local pick and pull, a few days later I noticed one of the spring eyes appears to be cut. In the picture it"s the top one. Can I run it like this or is it scrap metal?
If it makes any difference it is the front eye
Dapper Dan is offline   Reply With Quote
Old 05-15-2010, 01:16 PM   #2
bigblock73
yeller
bigblock73's Avatar
Re: leaf spring eye
I wouldn't run it
bigblock73 is offline   Reply With Quote
Old 05-15-2010, 01:23 PM   #3
cableguy0
Re: leaf spring eye
Looks broken to me. Spring is trash. You run the risk of it flexing enough to just pop out and cause all sorts of carnage. What are you trying to accomplish with changing springs?
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 05-15-2010, 03:52 PM   #4
Dapper Dan
Dapper Dan's Avatar
Re: leaf spring eye
The previous owner removed a couple leafs to lower the rear. I want to go lower with a flip kit but with the current leaf springs that would put me too low. I got these to raise it back up and then flip it, if that makes sense. I got 56" because that is all the pick and pull had. I was going to move the hanger
Since the bottom carries the weight could I weld a piece back on the top?
Old 05-15-2010, 04:00 PM   #5
cableguy0
Re: leaf spring eye
Welding on that is going to make the metal brittle. I wouldnt mess with them. There is force on all sides of that spring eye. Everytime you stand on the throttle the springs wrap up a bit.
Old 05-15-2010, 05:08 PM   #6
Dapper Dan
Dapper Dan's Avatar
Re: leaf spring eye
Ok thanks. Think I might be able to pull a couple of the shorter leafs out of the 56" pack and put them on my 52" pack?
Old 05-15-2010, 05:18 PM   #7
cableguy0
Re: leaf spring eye
How low are you trying to go it might end up cheaper to just new lowering springs and skip the flip kit altogether. By the time you factor in the cost of the new bushings etc on the old springs plus the flip kit your probably right in the neighborhood of a set of drop springs that will ride and handle better.
Old 05-15-2010, 07:14 PM   #8
Dapper Dan
Dapper Dan's Avatar
Re: leaf spring eye
about 6" where can you get drop leaf springs from? Only place I have seen is brothers trucks and they are $400-$500
Old 05-15-2010, 07:28 PM   #9
cableguy0
Re: leaf spring eye
Theres a couple vendors on here that deal in suspension stuff. I would check around with some of the smaller guys see what they can round up. That price is insane for leaf springs. You could have a set made at fallsway spring for half that.
Old 05-15-2010, 07:40 PM   #10
Dapper Dan
Dapper Dan's Avatar
Re: leaf spring eye
I'll check around thanks for the help!
