Stock Oil Gauge Fitting Size?
My stock mechanical oil pressure gauge has fitting on the back that is both male and female. The male fitting is about the size of 1/8 npt but just a little bigger. It is not 1/4 npt, does anyone know what size female fitting will work here?
#2 | |
Re: Stock Oil Gauge Fitting Size?
Those are uaually a compression type fitting where the line connects.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. ![]() |
They use a "threaded sleeve" nut to connect the tubing to the back of the gauge.
The threaded sleeve is a form of compression fitting where the end of the nut itself (instead of a separate sleeve) compresses onto the tubing as the nut is tightened. I believe Weatherhead #6100x2 is the part number you want for the nut that'll fit onto 1/8" OD tubing and screw into the back of the factory gauge connector. It has 5/16"-24 threads. |
Thanks Ray,
I think my local Oreilly's has that fitting. Any idea if it will work with plastic line? |
I don't see any reason why they wouldn't work with plastic tubing. Personally, I'd recommend upgrading to copper though ... I just don't trust plastic line for oil gauges.
The Weatherhead catalog says these fittings are for use with aluminum and copper tubing but not recommended for steel tubing. However, GM used them on steel tubing without any problems on these trucks for years. Probably because this application isn't going anywhere near the 500 psi rating of these fittings. |
#6 | |
Chemist under the hood...
Current fleet: 2013 GMC Sierra, 5.3L, 4x4 1988 GMC Sierra, 305, Auto 1984 Jeep Grand Wagoneer, 360 V8 1997 VW Cabrio, 2.0L 2017 Toyota Rav4, 2.5L Stuff I wish I still had: 2013 Toyota Matrix [RIP] 1967 GMC 910 Fleetside, 283 V8 [1st Love-SOLD] 1987 Jeep Cherokee Laredo 4X4, 4.0 I-6 [SOLD} 1994 Chevrolet Caprice Classic, 5.7LV8 [SOLD] 1995 Chevrolet Astro AWD, 4.3L V6 (RIP) 1998 Chevrolet Suburban 4x4, 5.7L V8 [SOLD] |
OK, I will get the copper line.
