Old 02-12-2003, 12:50 PM   #1
perrosinpata@aol.com
perrosinpata@aol.com's Avatar
steering shaft ?
what is the length of the collapsable shaft?
perrosinpata@aol.com is offline   Reply With Quote
Old 02-12-2003, 01:14 PM   #2
crazy longhorn
Fabricate till you "puke"
From the rag joint to the large washer on the bottom of the column, I have 17" on my 69.......you need to add 2" for stock, as mine has been collapsed to slide my column down 2". crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 02-12-2003, 02:00 PM   #3
okietruck
What's involved in collapsing the shaft? I would like some more room since I'm larger than average.
'72 LWB Stepside
okietruck is offline   Reply With Quote
Old 02-12-2003, 02:18 PM   #4
crazy longhorn
The shaft is slipped together, & injected with (nylon?). I drilled the spots , & knocked it apart in the vise, did a little clean up to remove what rust was inside, & slipped it back together. After the column was located, I installed the shaft, & drilled & pinned it in 1 spot......you may not want a very big pin, as the collapseable design is for your safety(i used a hollow roll pin). The column itself has a hole that locates on a tang at the top, & the clamp around the bottom. You can remove the column, & redrill the hole, or slide it down, &snug it up(the later was my choice), but be carefull not to get the brake peddle in a bind(you will see what I am refering to if you try this). im not sure how you will be set on the nuetral safety switch, as mine is on the B&M floor shifter. Good luck....crazyL
Old 02-12-2003, 02:34 PM   #5
okietruck
Thanks, crazyl. The neutral switch is not a problem since I'm running a 3-speed manual on the floor.
'72 LWB Stepside
Old 02-12-2003, 02:42 PM   #6
crazy longhorn
No trouble! You can probably squeeze a little more than the 2", but for myself @ 5'9", i just needed a little more room. i also have a shorter 1" adaptor on a flat dish Grant wheel that gave a little more space.....the Jazz plastic buckets are not adjustable. Good luck....crazyL
