Old 02-12-2003, 01:20 PM   #1
WB72
Before and After
WB72's Avatar
Question Is it possible to lower a 3/4 ton?
I would love to lower my 72 C20 3-5 or 4-6 ( I don't want to C Notch)if it is possible, I can get lowered springs custom made from a supplier that I use @ work, but they had a few questions about the geometry.
Front, Is there someone who makes a lowered spindle that will fit on a 3/4 ton? (it will not be hauling any weight so if a 1/2 ton will fit, what drop should be applied by the springs).
Rear, How much drop should be done by springs and how much by blocks.
If anyone has done this, to any extent, please let me know where parts came from and how they worked.
Not Grandpa's C-20 anymore...
383 Stroker 425HP, 485Ft/Lbs
Lowered 3.5" Front / 5" Rear
66,000 miles.
Alberta, CANADA
WB72 is offline   Reply With Quote
Old 02-12-2003, 02:52 PM   #2
crazy longhorn
Fabricate till you "puke"
spindles are available for a 3/4 ton, but a little pricey as compaired to the 1/2 ton pcs. Try to figure about 2" max on a front spring drop to keep geometry in check. At the rear, The 1/2 ton guys are going as much as 6" without a notch.....but I think I would stay with 5" on the 3/4 as max. The 1/2 ton trucks will handle about 2" of drop on a block with 15" wheels, & still be above scrub lines......you may be able to go 2 1/2" with a 16 or 16.5 wheel. check with some of the vendors on the board for spindles. Good luck...crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 02-12-2003, 03:33 PM   #3
ozarkhippie
There is a lowered 3/4 in a town near me. I had to look twice to figure out it was a 3/4. It had 15 inch wheels.
Buy Sale or Trade
71 3/4 4x4
72 1/2 ton cheyenne 4x4
ozarkhippie is offline   Reply With Quote
Old 02-12-2003, 03:44 PM   #4
Bustedup
Sure they can. I have reworked lower control arms with 2 in lower springs in the front and 4 in lower springs in the back. I did have to notch the rear cause I was hitting the frame.
I need to get a better picture.
PS Anyone can lower a 1/2 ton!!!
Bustedup is offline   Reply With Quote
Old 02-12-2003, 05:52 PM   #5
WB72
Before and After
WB72's Avatar
If I use 2"lower springs in the front, without dropped spindles, how much would I drop the rear to have it sit level?
????? Springs, blocks or both ???????
I have read numerous threads and I have figured that the rear should be 1 1/2"to 2"lower than the front. Is that the idea?
66,000 miles.
Alberta, CANADA
Old 02-12-2003, 06:06 PM   #6
crazy longhorn
4" should be pretty close.....crazyL
Old 02-12-2003, 06:59 PM   #7
Vince M
Vince M's Avatar
Early Classic Enterprises sells conversion dropped spindles along with the stock height for a 3/4 ton. These will convert it to 1/2 ton with a five lug pattern if your interested.
Check out Early Classic Enterprises
68 Chevy CST SWB w/LS1, carb & 700r4. Golden Anniversary clone with a few improvements.
Vince M is offline   Reply With Quote
Old 02-12-2003, 08:42 PM   #8
67cst
i love summertime
67cst's Avatar
i was at a car show about 3 summers ago down in omak wa, there was a yellow 3/4 ton 4x4 early 50's ford, it was slammed...how cool is that?¿?¿?¿
1967 shortbox stepside Chevy, 365 hp 327, th400.
GLOVE BOX LIGHTS FORSALE, click link for info
http://67-72chevytrucks.com/vboard/s...d.php?t=273724
67cst is offline   Reply With Quote
