Old 05-15-2010, 08:33 PM   #1
tbirdman88
87 short crewcab
tbirdman88's Avatar
89 suburban parts into 82 short bed
just bought a 82 short bed with manual doors,and a 89 suburban for parts. trying to find the thread on rear suburban gas tank install, also need to know if i should use the dash wiring,under hood wiring,abs master cylinder,fuse block. I guess i'am asking should i update everything under the hood and inside cab. I want to use the fuse block so every thing will just plug back in including the headlight harness.
tbirdman88 is offline   Reply With Quote
Old 05-15-2010, 09:15 PM   #2
knightowl73
TUKE-NoBullChit Customs owner
knightowl73's Avatar
Re: 89 suburban parts into 82 short bed
well then id use everything then, but id also cut out the 89 dash too and get that big radio opening if i were doing it.
someone will ring in on the tank install.
OWNER @ NBC Customs...No Bull Chit....'92 GMC C2500 ECSB 350/TH400, '57 FORD SKYLINER (My dad's for now, but its really mine-you'll NEVER see a cooler car at 7 years old lol), '42 ford rat rod shop truck (new project), 91 CHRYSLER VOYER MINIVAN (shop van for now)
http://www.facebook.com/#!/nbc.customs
knightowl73 is offline   Reply With Quote
Old 05-16-2010, 12:33 AM   #3
SBTork
Garage wrench
SBTork's Avatar
here is some info on the suburban/blazer tank install "how-to"
http://www.captkaoscustoms.com/blazertank.html
-Adam
90 V1500 GMC Suburban 350/700R4/NP241.....
01 Saturn SL1 stock DD.....
SBTork is offline   Reply With Quote
Old 05-16-2010, 08:28 AM   #4
tswore
built not bought
tswore's Avatar
I used a suburban tank in mine. It is pretty big. I think that if it its going in a 2wd rig it wont work. The front of the tank in mine sits over the rear end. I dont know if they had a smaller tank in some of the suburbans like the balzers.
MY BUILD THREAD "project: what you doin that for?"
http://67-72chevytrucks.com/vboard/s...d.php?t=382503
tswore is offline   Reply With Quote
Old 05-16-2010, 08:34 AM   #5
tswore
built not bought
tswore's Avatar
Also, to keep the tank from hanging too low, I kept the top of the tank higher than the frame rails. So I had to clearance one of the ribs on the bottom of the bed. (sorry no pics of that)
