Old 05-16-2010, 02:21 AM   #1
Nukes16
Nukes16's Avatar
Tailgate band dent removal
Any suggestions or success stories on taking minor dents out of the aluminum tailgate bands?
Cheers
Nukes16 is offline   Reply With Quote
Old 05-22-2010, 08:29 PM   #2
Goldfinger
Goldfinger's Avatar
Re: Tailgate band dent removal
I would assume sticking it in a vise protected by foam and applying pressure to return it the the original shape. however i've never been able to find a tailgate band.
1985 C10 Custom Deluxe LWB 305/700r4 [ Goldfinger ]
1999 k3500 crew cab dually 6.5tdi/4l80e
Goldfinger is offline   Reply With Quote
Old 05-22-2010, 09:06 PM   #3
68Timber
I know the pieces fit
68Timber's Avatar
Mine has a small dent in it, I'm not too worried about it. Paintless dent removal guys do magic on cars beat to hell by hail. I've been through that. I think I can do a good enough job on a driver by working a spoon on the backside while holding something flat on the frontside.
If you need perfection, find a local paintless dent removal guy to fix it for you. They usually charge $40 or so per dent but you may be able to work a deal if you take it off and take it to him, it'll make his job much easier.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 05-22-2010, 11:39 PM   #4
N2TRUX
Happy to be here
N2TRUX's Avatar
Biggest problem is going to be gaining access to the dent. If it's in the middle area, there is a backing plate that covers that part up.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 05-23-2010, 01:21 AM   #5
misternash2
anybody tried the heat gun and dry ice trick?
misternash2 is offline   Reply With Quote
Old 05-25-2010, 07:24 PM   #6
68Timber
68Timber's Avatar
Does the backing plate serve any good purpose? I'm just curious if it can be removed if need be.
John
74 Honda Z50 build
Old 05-25-2010, 08:12 PM   #7
Stitch
Location: Where I come from, it's cornbread and chicken...
it's how the band is mounted....I was looking at one the other day, and I think you can bend some tabs and remove the backing plate, and then reinstall it
Stitch is offline   Reply With Quote
Old 05-25-2010, 08:17 PM   #8
RandyP
Getting Old; Going Broke
RandyP's Avatar
The back hides, so a hole could be drilled for access by a PDR tech. With it being fairly thin aluminum, not sure how well it would PDR to be honest, but would well be worth the try. Lord knows I'm going to make my PDR guy fix a big dent in the molding on the back of my cab.
RandyP is offline   Reply With Quote
