Old 05-16-2010, 08:46 AM   #1
Indy72
72 rear suspention
Is it possible to convert from trailing arms to using rear leaf springs?If so what is needed?
Indy72 is offline   Reply With Quote
Old 05-16-2010, 12:40 PM   #2
mclairmo
Re: 72 rear suspention
Yes, it is. Look under a 67-72 GMC to find out what is needed or maybe the LMC catalog has some diagrams of the needed brackets, etc.
mclairmo is offline   Reply With Quote
Old 05-16-2010, 01:42 PM   #3
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
I've heard of people wanting to go from leaf springs to trailing arms... but not the other way around...
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is online now   Reply With Quote
Old 05-17-2010, 09:20 AM   #4
BOOB
BOOB's Avatar
Anything is possible. I'm not sure if there are factory holes in the frame that allow the hangers and shackles to bolt up, but you would need of course the leaf springs, front spring hangers, rear spring shackles and brackets, u-bolts and spring perches. It wouldn't be too hard. I could go over the details if you are REALLY going to do it. Why do you want to convert?
1970 Short/Fleet C-10 (Project)
-Slammed and Tubbed
1955 Cameo
-Straight six, Turbo Hydro option
1955 BelAir 2 door post
-All original down to the oil bath air cleaner
1964 Corvette
-All power A/C 327 4 spd. tanker
BOOB is offline   Reply With Quote
Old 05-17-2010, 09:43 AM   #5
Willys47
Willys47's Avatar
Would a 4x4 have the right hangers to make this change or are the frames different ? just a thought
I was hooked on these trucks since 1982 when I drove my budys fathers 1968 Custum GMC 396 automatic dana 60 rear with a power lock diff what a ride more fun then we will we can ever tell!!
Willys47 is offline   Reply With Quote
Old 05-17-2010, 02:52 PM   #6
mclairmo
I believe the 4x4 stuff would be different.
Old 05-17-2010, 03:10 PM   #7
lofly'a
lofly'a's Avatar
wish you were closer, i have the whole setup rearend and all from my 71 GMC. i went the other way (to coils/trailing arms).
-02 avalanche (daily driver)
-66 gto ragtop 389/400 (garage queen, hand-me-down from dad)
-72 Tribute Trans Am (6.0LS/T56 6-speed) in progress
-2003 YUKON (Wife's)
-71 gmc swb fleet (current project, gonna shave everything, bags, stuff w/ 20's, gen III powertrain)
-48 3100 SWB - 12/31/23 LONG TERM Project
lofly'a is offline   Reply With Quote
Old 05-17-2010, 04:44 PM   #8
Indy72
I guess Im wrong,I thought the leaf spring set up was better.I will keep what I have. Thank's
