Old 05-16-2010, 01:10 PM   #1
Benelli
Watchin the rust grow
Benelli's Avatar
Brake Box?
Under the radiator, there's a box that the brake lines run to and from. What is this part called?
1979 Chevy K10 (H/D Front end) - 350 w/ Holley Truck Avenger, Weinald Intake manifold, headers, bored .060 over, mild cam, Built up TH350 (TranStar Shift kit) with a part-timed NP203 t-case SOLD ($3,000)
1997 Chevy Silverado 1500 - 4.3 vortec, extended cab, 21 highway MPG, stock. "Red" SOLD ($3,000)
1987 Toyota 4wd Pick-up - work in progress, future DD SOLD ($1,850)
1998 Dodge Ram 2500 Cummins 5spd Quad cab - old 12 valve with some work done
2004 Chevy Silverado - Black, 4x4, 5.3L, stock for now
Underneath that rust is a heart of gold
Benelli is offline   Reply With Quote
Old 05-16-2010, 02:04 PM   #2
Scootin 81 C20
3/4 Ton Rodder
Scootin 81 C20's Avatar
Re: Brake Box?
Sounds like it could be very early ABS, but I'm not sure.
1981 Chevy Scottsdale C20 "Orange Crush": SOLD
1989 Chevy Silverado K2500: All Stock (For Now), 350 TBI/700R4. DD/Light Duty Toy.
Scootin 81 C20 is offline   Reply With Quote
Old 05-16-2010, 05:08 PM   #3
Prong
Re: Brake Box?
Proportioning valve (or combination valve in some circles).
Prong is offline   Reply With Quote
Old 05-16-2010, 05:40 PM   #4
78 Chevyrado
Re: Brake Box?
x2
78 Chevyrado is offline   Reply With Quote
Old 05-16-2010, 05:44 PM   #5
81ratrodc10
house of chevy's
81ratrodc10's Avatar
Re: Brake Box?
Originally Posted by 78 Chevyrado View Post
x2
x3
81ratrodc10 is offline   Reply With Quote
Old 05-16-2010, 08:25 PM   #6
Benelli
Benelli's Avatar
Re: Brake Box?
Alright. Here's the Real question.
I just replaced my master cylinder, and the brake booster is claimed to be only a few years old (I fairly trust the guy I bought the truck from).
My brakes are still pretty sprongy, especially when pulling something. And things can get a little hairy pulling. Would these cause spongy brakes, and are they even available to buy or rebuild one?
Old 05-16-2010, 08:48 PM   #7
73chevyman
73chevyman's Avatar
Re: Brake Box?
sounds like you need to bleed the lines and rid of the fluid....
http://67-72chevytrucks.com/vboard/group.php?groupid=37
73 C10 Fleetside
If it ain't a Chevy it's foreign
http://hotridesmag.com/
73chevyman is offline   Reply With Quote
Old 05-17-2010, 07:19 AM   #8
Turbo85GMC
Turbo85GMC's Avatar
Re: Brake Box?
Originally Posted by Benelli View Post
I just replaced my master cylinder...
Did you bench bleed the new master cylinder? Haven't replaced one myself, but I've heard/read from several people on the board that you have to bench bleed them. Just an idea.
'85 GMC 1500
"Friends don't let friends drive stock!"
Turbo85GMC is offline   Reply With Quote
Old 05-17-2010, 10:04 AM   #9
Benelli
Benelli's Avatar
Re: Brake Box?
I did that after I got it replaced.
Old 05-17-2010, 10:05 AM   #10
Benelli
Benelli's Avatar
Re: Brake Box?
Nope, I sure didn't. Didn't even know what bench bleeding was before I read this.
Old 05-17-2010, 11:03 AM   #11
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Brake Box?
It sounds like you still have air in your lines. You can gravity bleed them, but that takes forever. I have a trick that works pretty good. It does require two people to do.
I use the traditional method of bleeding with a twist. I have a piece of vacuum, line that fits over the bleeder valves. I run this down in to a half full bottle of fluid. Put your line wrench on the valve, then slip the hose hose on and run it in to the bottle.
Now get your partner to pump the brake and hold. Then open the valve till the pedal goes to the floor pushing air and fluid out. Close the valve and repeat. The difference with this method is you capture the fluid, and since the hose is submerged it won't allow air to be drawn back in the line.
This method has worked great for me...
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 05-17-2010, 02:37 PM   #12
73chevyman
73chevyman's Avatar
Re: Brake Box?
thats a pretty cool trick
73 C10 Fleetside
Old 05-18-2010, 12:23 AM   #13
Benelli
Benelli's Avatar
Re: Brake Box?
I guess I'll add it to the list of "Crap to do"
Thanks guys, always appreciate good quick honest answers.
