frame paint opinions
I have a 72K20 with moderate to heavy rust on the frame. All of the heavy rust is behind the cab.. Im going to pull the bed to repair the wood so I would like to take care of this problem while I can. The truck is parked inside unless Im driving it or plowing snow in my driveway. This is not a show piece, I use it as a truck. I have used POR in the past for truck bodies but I am seeing what other products others have used.
Re: frame paint opinions
I used POR 15 on my frame also but really if you remove surface rust and get down to some clean metal a coat of primer and paint should help protect the metal for years to come. Then you could even roll on some cheap diy bedliner stuff to help protect the paint.
1970 GMC- 454 DONT GIVE ME NO JIBBA JABBA!!! |
![]() Join Date: Oct 2009
I used the Eastwood chassis kit that includes a rust converter and a rust encapsulator that forms a durable primer for the top coat. I was very pleased with the results and was easy to work with.
Good luck with your project and keep us posted on the progress. Justin
Justin 71' C10 SWB 00' Dakota R/T 05' Z-71 Silverado 16' Z-71 Silverado Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=376904 |
I. was cheap and I wanted to be able to touch it up easily. Used Rustoleum "Hammered". Good stuff for a frame, dollar for dollar
thanks. Im looking for an easy product to use, some thing I could spray gun on with out days of prep. Ill check out Eastwood.
Rustoleum hammered is great i shot it through my gun with a 50/50 paint to thinner
68 GMC-Stripshow 70 Chevy Monte Carlo 72 Chevy Monte Carlo LOLO 72 Chevy Suburban Blurban 74 Vw Bug 78 Chevy k10 lwb 78 Chevy k10 swb 03 Cadillac Escalade-Duecesix 84 Cadillac Coupe Deville DeElegance ![]() ![]() B.O. A Lifestyle Money Cant Buy! Win,Lose, or Tie I'm a Raider till i die |
