Old 02-12-2003, 04:21 PM   #1
Locutus
Locutus's Avatar
Very hacked dash! any ideas for radio install
The previous owner hacked the dash to install gauges on a panel that was screwed to the dash. I don't really like having a panel screwed on dash but I have considered it. I just wanted to see if there were any other ideas about how to aproach this.
Locutus is offline   Reply With Quote
Old 02-12-2003, 04:29 PM   #2
Shane
Shane's Avatar
dude ... you need a new dash ....
Shane is offline   Reply With Quote
Old 02-12-2003, 04:33 PM   #3
Frank_Zeller
Frank_Zeller's Avatar
Try a Double DIN radio like is used in the newer GM and Dodges. Seen a 70 at the junk yard with one. Looked pretty good.
69 SWB C/10 5-6 drop 700R4
69 Firebird Convert 455 4 spd
70 Torino GT Convert
Austin-Texas
Frank_Zeller is offline   Reply With Quote
Old 02-12-2003, 04:35 PM   #4
Locutus
Locutus's Avatar
Well I have an aftermarket stereo I want to install. If it had the orginal cut outs for the stereo I would have no problems cutting it to fit but with this its way to big for a standard stero
Old 02-12-2003, 04:42 PM   #5
I think I would square it off with a dremel tool and weld body panel adhesive a panel back into the dash. Little bondo/liquid steel, sand & paint and it should look good and hold up well.
Old 02-12-2003, 06:30 PM   #6
NSANE68!!!
SLICER AND DICIER
NSANE68!!!'s Avatar
Or maybe a full BILLET custom dash, like mine
01 Tahoe 22's 2/4 drop and tv's
68 chevy money pit
51 chevy belair
95 Honda 900RR
05 GMC Siearra (company truck)
NSANE68!!! is offline   Reply With Quote
Old 02-12-2003, 06:40 PM   #7
72MARIO
72MARIO's Avatar
From the looks of it Get A New Rust free Cab !!!
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 02-12-2003, 06:43 PM   #8
COBALT
COBALT's Avatar
Yeah, I'd find a cab with an uncut dash (or at least one with the radio area uncut) and try to either put in a new dash, or cut a section out of a salvaged dash and weld it in.
'69 3/4 ton C20 2wd-350ci/TH400
'69 3/4 ton Custom 20 2wd-350ci/4sp Manual
'99 2wd 5.7 Chevy Tahoe
Seattle, WA.
COBALT is offline   Reply With Quote
Old 02-12-2003, 06:51 PM   #9
AndrewDT
AndrewDT's Avatar
Mine was chopped up too. What I was going to do was take a Radio Delete Plate and cut stock size holes in that and mount my radio in the plate. It'd cover the hole and look... semi-correct.
But you got a big hole!
'72 Suburban 4X4
"Save the Earth, kill yourself"
AndrewDT is offline   Reply With Quote
Old 02-12-2003, 06:57 PM   #10
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
I have heard about bezels you can buy at the stereo stores, but I don't know if they will cover that big of a hole. It looks like someone had a plate stuck on there previously. You could have someone fab up a billet plate to cover the hole. If you used a billet dash insert, ashtray plate and glove box plate, it would look really nice.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 02-12-2003, 07:08 PM   #11
landon4421
Life is Good !
landon4421's Avatar
let it be for now and look around at the wrecking yards in your area with a cab that still has the stock holes for the radio and cut it out and re weld the dash. That is what I had to do and you can not even tell that someone else had hacked it up. "Cobalt" has the right idea. I will post a pic in the morning. Landon
'72 Chevy C10 4x4 shortbed "Project"
'71 Chevy C10 2wd longbed "partsrunner"
'91 Chevy Burb 4x4 "kidrunner"
'14 Honda Accord Sport "commuter"
landon4421 is offline   Reply With Quote
Old 02-12-2003, 08:40 PM   #12
weasel29gm
SLOW BUT SURE,BUT CLOSER
Get creative and fix it and save money. Like Plaf said find a plate and put it back or make one out of stainless etc.
69 C-10, OWNED 35YRS... 350 over 30, 350 Turbo, 3:73 Posi P/S, P/B Black with red and black int. ''LOVE THESE OLD ''TRUCKS.......
weasel29gm is offline   Reply With Quote
Old 02-12-2003, 08:47 PM   #13
jku72
Man, that hole's big enough for a phonograph!!! I guess Id make a plate, and put it on. Make the plate pretty enough, and it wont look that bad. You can then make cutouts of the correct size in the plate. A stock look is out of the question.
jku Cornville, Maine
68 C10 burb
42 Willys MB
46 Dodge WF-32 1.5 ton
53 & 56 Olds'
60 Cadillac
22 Dodge Brothers
jku72 is offline   Reply With Quote
Old 02-12-2003, 08:54 PM   #14
67cst
i love summertime
67cst's Avatar
i agree with jku72, make a nice rectangular plate and have a shinny carrige bolt in each corner with the proper size cut out for the deck
1967 shortbox stepside Chevy, 365 hp 327, th400.
GLOVE BOX LIGHTS FORSALE, click link for info
http://67-72chevytrucks.com/vboard/s...d.php?t=273724
67cst is offline   Reply With Quote
Old 02-12-2003, 09:56 PM   #15
minibike
minibike's Avatar
I have a junk cab with a good donor dash area. I would be willing to cut out the radio area for $20 plus shipping.
69 SWB
LT1/4L60E
www.classicplace.com
minibike is offline   Reply With Quote
Old 02-12-2003, 09:56 PM   #16
Project1970
14.1 @ 96MPH
Project1970's Avatar
That is one HACKED dash...I would go look for a truck with either an uncut or even a less-cut radio opening, cut it out, and weld it in there. It looks like they cut out some of the beveled area there...
What you should do, at the least, is try to reconstruc the beveled-in area as well as you can (unless you want to cut it all out and weld in a flat plate, I've seen that done, it isn't half bad but I prefer it sunken in), and then weld in a plate to fill the beveled area, and then cut away for your new radio.
Hmm...random thought...I bet if someone made patch panels for that area, they'd be decently popular.
Project1970 - LS1 Swap Complete!
Project1970 is offline   Reply With Quote
Old 02-12-2003, 10:46 PM   #17
Blue68
Blue68's Avatar
Something I'm curious to see, is one of two things. Both are a plate (which judging by the screw holes was on yours) that fits flush across the recessed area and has mounting options for stereos (din, two dial original). One option is for those guys that use the billet aluminum glove box and bezels and use the same material, the other would be a flat steel option. Or I suppose you could go Caddy and put in a wood face plate around it with a nice stain to match a nostalgic wood steering wheel. Then the hacked dash disappears and you don't have to figure out how to mount one.
Just my idea.
http://home.comcast.net/~r.landrum/w...tos.html-.html
'68 C-10 LWB, '98 Z-71 350 w/accessories (Serpentine), Edelbrock Performer, Edelbrock 1405 (600cfm) carb, GM HEI, CompCam Extreme 4x4 roller cam, Thorley Headers, Carter Electric Fuel Pump, Vintage Air, 700r4, 3.73, disc brakes and power steering upgrades.
Blue68 is offline   Reply With Quote
Old 02-12-2003, 10:55 PM   #18
nosto
Flamin' Bass
nosto's Avatar
I, too, was blessed with a total hacked dash in the radio area. All I got was the hacksawed hole, not even a radio. Since I went to bags, I needed somplace to put the gauges and switches, so I filled in the hole with them. The radio/CD will be elsewhere; under dash, in glovebox, in console, don't know yet.
Rick Olson /nosto/
Galloway, NJ
Pics : http://community.webshots.com/user/nosto53
1972 Triumph TR6 - full resto, now with a Toyota 5-speed
1975 F**D F-100 - rusty, but reliable
1982 HD XLH-1000
1967 C-10, shortstep, 350/M21 4spd, nitrogen tank fills fast bags on 4 corners, Toyo 255/45X20s on American Eagle 221 20X8s, shaved locks and handles, antenna, fuel filler, tiny C-notch, rear fuel tank, long headers, Edelbrock, worn 600 Holley, Checkmate flush hard cover, rear pan, custom LED taillights - painted it, too! But don't like it so I'm gonna do it again!!
nosto is offline   Reply With Quote
Old 02-12-2003, 11:35 PM   #19
EdB
I would find a donor piece and weld
it in.
EdB
EdB is offline   Reply With Quote
Old 02-12-2003, 11:40 PM   #20
da-burb
"Ochre Ogre"
da-burb's Avatar
I'm betting that it wasn't a radio in there. It looks like it was a .6 cubic foot 900 watt microwave. I think the last owner couldn't live without his micro-wave popcorn.
Bowtie Truck Stop Inc.
Mid-West GM Truck Restoration Parts Supplier
Your Key Parts, Auto Metal Direct, Dynacorn,
and Goodmark dealer.
like us @ www.facebook.com/BowtieTruckStop
1971 C-10 Suburban (Ochre)
1971 K-10 Suburban (Ochre)
1972 C-10 Suburban (Ochre)
1972 K-20 Suburban (Yellow- that just aint right!)
Springfield, Minnesota 56087
da-burb is offline   Reply With Quote
Old 02-13-2003, 01:00 AM   #21
69 Short Fleet
I agree with palf70 and jku72, weld in a plate, Holy Hanna did that guy go nuts with his jigsaw or whatever!!!, nosto thats the first one I've seen with gauges/switches, very original idea and looks super!!! Later, Doug
69 Short Fleet is offline   Reply With Quote
Old 02-13-2003, 03:55 AM   #22
O'l Buck
Recovering Truck Driver
O'l Buck's Avatar
We replaced the radio in my sister's 91 chevy with an aftermarket CD Player. The radio's in those things are huge. I picked up an installation kit from Wally World for about $15 I think. It had a big bezel that surrounded the radio. You might be able to brace the radio up good and put one of those kits in there to fill up the hole. Man, that's one hacked up dash.
67 K-20 350, SM465, Eaton rear, 4.56 no spin option
00 Dodge 2500 4x4, 24V cummins, 5 speed
Chad
South Central Nebraska
O'l Buck is offline   Reply With Quote
Old 02-13-2003, 09:57 AM   #23
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
When I got my truck, it was hacked just about as bad.
I bought some aluminum tread plate from Lowes and installed that.
There are only 2 options; cover the hole or weld in a piece from another truck.
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
Old 02-13-2003, 11:33 AM   #24
yellowgmc
Getting cabin fever?!?!?!
yellowgmc's Avatar
take a 12 guage and strategically blow holes in the truck. sell it on ebay as a bank robbers getaway truck. the other ideas are probably better, but this would be fun!
Member of the Discs Up Front Club
1972 GMC 1500
1994 F-150 XL 4x4
Tact is for people not whitty enough to be sarcastic
yellowgmc is offline   Reply With Quote
Old 02-14-2003, 02:59 PM   #25
Brad
Out of the carpool lane.
Brad's Avatar
I used to work at a TAP Plastics. It's a west coast plastics store for the do-it-yourselfer. We carried ABS plastic that had a grain pattern to it. Sold in thickness of 3/32, 1/8, 1/4. You could make a panel out of this and it would look much better.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red
1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!)
2000 Honda VFR in the faster yellow!
2008 Husqvarna TE-610
1967 C-10 SWB 'Six Appeal'-Gone but not forgotten...
Brad is offline   Reply With Quote
