Old 05-16-2010, 09:42 PM   #1
cwilkie
Chance
cwilkie's Avatar
Aluminum vs Cast Iron Intake
Will a Summit Racing SUM-226022 Aluminum Intake (http://www.summitracing.com/parts/SUM-226022/) out perform a GM Stock Cast Iron 3883948 Intake? I have been trying to decide this for most of the winter. If any of you has this Summit Intake do you know if it has the trunk for a divorced choke? Any help will be appreciated.
1968 Chevrolet Stepside
BB 396 w/TH400
1972 Chevrolet 3/4 Ton 4x4
BB 496 w/TH400
cwilkie is offline   Reply With Quote
Old 05-16-2010, 10:17 PM   #2
hchad18
hchad18's Avatar
Re: Aluminum vs Cast Iron Intake
Any aluminum intake should outperform a cast iron one. They weigh less, they look cooler and usually Summits stuff is usually made by someone who already makes that product, ie Edelbrock, or Weiand in your case.
hchad18 is offline   Reply With Quote
Old 05-16-2010, 10:25 PM   #3
vectorit
What?
vectorit's Avatar
Just the heat dissipation alone with the aluminum intake is a huge benny over the cast iron intake.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 05-16-2010, 10:28 PM   #4
jiggityjoe87
I just change my 350 from cast iron to aluminum intake and what a weight difference it makes. My aluminum manifold was easily 1/2 the weight of the cast iron manifold and it will produce more power than the stock manifold
jiggityjoe87 is offline   Reply With Quote
Old 05-16-2010, 10:34 PM   #5
mclairmo
A modern recently designed dual plane intake would easily outperform the 40 year old GM design, regardless of material used to cast it. Aluminum has the added benefit of weight reduction. Don't know if it allows for a divorced choke but looking at pics of it should answer that question. If it were me, I would run the Summit Carb or a Holley with electric choke on top of that new intake.
mclairmo is offline   Reply With Quote
Old 05-16-2010, 10:42 PM   #6
cwilkie
Chance
cwilkie's Avatar
That is great advice guys. I was hoping the Aluminum Intake would be your recommendation. Are there any benefits to going with an electric choke? I have a divorced choke right now but I do not know much about the electric choke.
I am going to go with this intake.
I am undecided on which carb to purchase. Here are the links for both the divorced and electric choke. These are JET Streetmaster Quadrajet Stage 2 Carburetors from Summit. They are identical except one is Divorced Choke and the other is Electric Choke. Is electric choke more reliable?
1. Divorced Choke
2. Electric Choke
BB 396 w/TH400
BB 496 w/TH400
Old 05-16-2010, 10:43 PM   #7
tasian
tasian's Avatar
hands down in anyway you can think of the aluminum is going to outperform it
Betsy's build
70 c20 4 speed 406sb
tasian is offline   Reply With Quote
