05-16-2010, 11:21 PM | #1 |
Future TOTM Winner
Pic request 32 spline newer style NP205
Can someone provide me with a few pics of the newer style NP205 with a 32 splined input shaft? This would be the one with the round mounting bolt pattern NOT the more common "Figure 8" or "racetrack". I believe this T-case would have come behind the late 80s/early 90s model 1 tons with a th400 tranny, but maybe there are more examples. Either way, a few pics of the mounting surface out of the vehicle on a bench or something would be greatly appreciated. While we are at it, feel free to include the adapter if you have it. THANKS!
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces) 72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts 2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver Check it out www.lsdyno.com |
05-17-2010, 07:48 AM | #2 |
Re: Pic request 32 spline newer style NP205
I have one but no pics. These were on the 86 to 91 1 tons with the TH400 and the 4 speeds. Same t-case, different adapters. Also have the long 32 spline input.
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 6” lift 1999 GMC Yukon 350/4L60 4" SAS |
05-17-2010, 01:49 PM | #3 | |
Future TOTM Winner
I agree about the year model and long input shaft details that you mentioned.
05-17-2010, 07:35 PM | #4 |
8 track went to aboot 84-85 for the auto, not sure on the stick. Then 85 if not 86 for sure cause that's where I got my 2 from, they went to the round 6 pattern like the pic you posted. They are the same for auto or stick, the difference is in the adapter. The adapter for the stick is crazy long, whereas the auto is 6" IIRC.
05-17-2010, 07:46 PM | #5 |
Real Projects never die
1991 205s had the vss as opposed to cable speedos if i remember right as well.
Ill put it this way, ive got a few lawn ornaments My name tag says Ryan KansasTwister On other forums
05-18-2010, 07:15 AM | #6 |
And the only year was 91, and only in crew cabs/cab n chassis trucks. I've seen one, and it wasn't in a junkyard or I would have it.
05-18-2010, 03:43 PM | #7 | |
The 465 with the 32 spline mainshaft had a crazy long stickout. Here is a pic:
1969 GMC K2500 1996 Honda Accord 2007 Kawasaki KLR 650 |
